Raspberry Pi Dual Cooling Fans Kit (Compatible for Raspberry Pi 3B/3B+/4B)
$6.50
SKU: FIT0817
Aluminum heat sink with dual fans for Raspberry Pi models 3B/3B+/4B, featuring easy adhesive installation, 5V, 1.5W power, and 7500rpm speed.
Purchase this product and earn 65 reward points, which are tied to VIP membership program. Learn More >
This is a one-fan Raspberry Pi radiator compatible with Raspberry Pi 3B/3B+/4B. The heat sink is made of high-quality aluminum, and the surface is designed with slots, which is more conducive to heat dissipation. Two 7mm 9-blade cooling fans are installed on the aluminum heat sink. The heat sink comes with adhesive backing for easy installation. Clean the surface of the Raspberry Pi CPU, then tear off the adhesive film and stick the heat sink to the surface of the CPU, then you are good to go!
Raspberry Pi Dual Cooling Fans Kit Raspberry Pi Dual Cooling Fans Kit
  • Working Voltage: 5V
  • Power: 1.5W
  • Speed: 7500rpm
  • Weight: 12g
  • Applicable to 3B/3B+/4B
  • Size:
  •             Large Heat Sink: 50*25*13mm / 1.97*0.98*0.51 inch
                Small Heat Sink: 9*9*5mm / 0.35*0.35*0.2 inch
  • Large heat sink with fan x1
  • Small heat sink x2
  • Raspberry Pi Dual Cooling Fans Kit (Compatible for Raspberry Pi 3B/3B+/4B)
