Raspberry Pi Single Cooling Fan Kit (Compatible for Raspberry Pi 3B/3B+/4B)
$5.00
SKU: FIT0816
A single-fan radiator for Raspberry Pi 3B/3B+/4B, made of aluminum with adhesive backing for easy installation. Specs: 5V, 1.5W, 7500rpm, 12g.
This is a one-fan Raspberry Pi radiator compatible with Raspberry Pi 3B/3B+/4B. The heat sink is made of high-quality aluminum, and the surface is designed with slots, which is more conducive to heat dissipation. One 7mm 9-blade cooling fan is installed on the aluminum heat sink. The heat sink comes with adhesive backing for easy installation. Clean the surface of the Raspberry Pi CPU, then tear off the adhesive film and stick the heat sink to the surface of the CPU, then you are good to go!
Raspberry Pi Single Cooling Fan Kit(for Raspberry PI 3B/3B+/4B)
  • Working Voltage: 5V
  • Power: 1.5W
  • Speed: 7500rpm
  • Weight: 12g
  • Applicable to 3B/3B+/4B
  • Size
  •          Large Heat Sink: 25*25*13mm / 0.98*0.98*0.51 inch
             Small Heat Sink: 9*9*5mm / 0.35*0.35*0.2 inch
  • Large heat sink with fan x1
  • Small heat sink x2
  • Raspberry Pi Single Cooling Fan Kit (Compatible for Raspberry Pi 3B/3B+/4B)
