This time DFRobot brings you an electric push rod. Despite a mini body, it comes with a thrust of up to 128N and a stroke of 100mm when powered by a voltage of 6V.
With simple wiring, this small but practical 6V electric push rod of short-stroke can be used for applications like access control, DIY lifting projects, electric telescopic poles, etc.
Dimension
May 22, 2025
Like it much! Good quality, easy to connect and use.
