Industrial Isolated USB to RS485 Converter enables reliable communication between USB-enabled computers and RS485 industrial devices while also providing a high-voltage DC output for field equipment. Designed for demanding industrial environments, this USB‑to‑RS485 communication interface delivers stable serial conversion and convenient power delivery through a single module. The converter draws power directly from the USB bus, eliminating the need for an external adapter while simplifying wiring for control systems, instrumentation, and industrial monitoring setups. With robust electrical protection and broad operating system compatibility, this industrial serial communication adapter provides a dependable bridge between modern computers and legacy RS485 networks.
Figure: Industrial Isolated USB To 485 Converter
Integrated High-Voltage Power Output
This industrial USB‑to‑RS485 interface includes a DC voltage output capability reaching up to 36V, allowing connected industrial instruments to receive both communication and power support from a single module. Such integration simplifies wiring and reduces the need for additional power supplies in field installations. The design makes this industrial communication converter particularly suitable for automation equipment, industrial sensors, and monitoring devices requiring higher operating voltages.
Industrial-Level Protection Design
Built for harsh electrical environments, the serial communication converter integrates 15KV ESD protection and supports up to 600W lightning surge protection. A combination of self‑recovery fuse and TVS protection circuitry safeguards the communication hardware from over‑current, over‑voltage, and reverse connection risks. This protection architecture significantly enhances reliability and extends operational lifespan in industrial automation systems and outdoor installations.
Wide Compatibility and Stable Communication
This USB‑to‑RS485 communication module complies with the USB 2.0 standard while remaining backward compatible with earlier USB versions. Full RS485 protocol compatibility ensures seamless integration with industrial control equipment and serial devices. Broad operating system support includes Windows 98/ME/2000/XP/7/8/10/Vista and Mac systems, making the converter suitable for diverse industrial computing environments and maintenance platforms.
Plug‑and‑Play Operation with Visual Status Indicators
Plug‑and‑play functionality allows immediate deployment without complicated configuration, while hot‑swappable capability supports connection during active system operation. Integrated RX and TX indicator LEDs visually display communication status, enabling convenient diagnostics and monitoring. The RS485 interface supports adaptive communication speeds ranging from 300 to 921.6 kbps, ensuring flexible integration with a wide range of industrial serial devices.
This industrial USB‑to‑RS485 converter is suitable for industrial automation systems, serial device communication, data acquisition equipment, environmental monitoring platforms, and other applications requiring reliable RS485 communication combined with robust electrical protection.
