This active, isolated RS485 to UART signal transfer module comes with protection circuits such as power isolation and TVS.
Compatible with most main controllers, it has the characteristics of fast communication speed, stable and reliable performance, high safety, etc.
It can be applied to various industrial sensors, industrial control equipment or applications that require RS485 signal conversion.
Connect with Arduino Board
Connection Diagram (Use serial port to read sensor data)
Board Overview
Sep 09, 2025
excellent quality, will order again.
Aug 27, 2025
Reliable signal conversion, easy Gravity connector system. Solved my communication issues immediately.
Aug 27, 2025
Works well with the anomometer and wind direction units.
