This HDMI to RJ45 Ethernet Cable Extender consisting of a transmitter and a receiver is designed to synchronously transmit audio and video signals up to 30m with zero latency.
The module supports HD 1080P video signal transmission.
Gold plated HDMI interface, anti-oxidation, not easy to rust.
No power supply required, plug and play.
The module case is made of ABS material, stable and durable, longer service life.
The extender consists of a TX transmitter and an RX receiver, which extends the HDMI signal to 1~30 meters with one CAT 6 cable.
The module can be connected to main-controllers or external displays, like Raspberry Pi, LattePanda, computers, HDTV, and projectors.
