Miniware DT71 Mini Digital Tweezers
$99.00
SKU: FIT0847
Mini digital tweezers offer multifunction measurement, signal generation, and replaceable parts. Features include OLED display, smart gestures, and 10-hour battery life.
Purchase this product and earn 990 reward points, which are tied to VIP membership program. Learn More >
DT71 mini digital tweezers is a tool that integrates multi-function measurement, signal generator, and fully differential input measurement.
It has a unique trinary structure that includes a controller, measuring arm and tweezers head, which can be flexibly replaced and combined.
There is an OLED screen on the 360° rotatable controller, which provides visibility from all angles. With smart gesture recognition, it can automatically recognize left and right operations and adjust the screen display.
Different from other LCR testers, DT71 has no physical buttons. Instead, there is a hidden touch button on the top of the controller, which can be easily operated with a light touch.
The test arm uses magnetic elasticity to provide easy clipping, ergonomic, and durable structure.
It comes with gold-plated interchangeable tweezer tips, enabling higher measurement accuracy in various usages.
The built-in dual rechargeable lithium batteries can last 10 hours for one full charge, and the charging time is about 2 hours.
A variety of measurement types are available for measuring resistance, capacitance, inductance, voltage, frequency, diodes and other devices.
Tweezers have manual and automatic recognition modes. In automatic mode, DT 71 can automatically identify SMDs including resistance, capacitance, inductance and diode, and display primary and secondary parameters, which is very useful for quickly distinguishing different components.
At the same time, the built-in miniature waveform signal generator can output a variety of waveform signals, providing a perfect solution for the debugging and maintenance of complex electronic systems and the classification and detection of discrete chip components.
With a compact and mini size, it is convenient to carry around, overturning the appearance restrictions of traditional desktop and hand-held measuring instruments. It is an innovative work in the appearance and structure design of measuring instruments and can be used in any place such as laboratory, workbench, warehouse and outdoor.
With intelligent functions such as automatic identification, automatic shutdown, firmware upgrade, etc.
Measurement parameters Range Resolution Accuracy
Resistance 0.1Ω~1KΩ 0.1Ω 0.5%+2
1KΩ~2000KΩ 1KΩ 0.5%+2
Capacitance 0.1pF~1000pF 0.1pF 2%+3
0.001uF~400uF 0.001uF 2%+3
Inductance 1uH~1000uH 1uH 5%+3
1mH~50mH 1mH 5%+3
Voltage 1mV~100mV 1mV 2%+5
0.1V~40V 0.1V 1%+3
Frequency 10Hz~1KHz 10Hz 0.1%+3
1KHz~20000KHz 1KHz 0.1%+3
Diode Silicon diode, Schottky diodes, LED (forward voltage 0.1~3V) 0.1V 1%
Maximum input voltage -5V~+50V
Input resistance 1MΩ
  • Three-section split structure
  • OLED screen
  • Intelligent posture judgment
  • With hidden touch buttons
  • Ergonomically design
  • Operating hours: 10 hours of continuous work
  • Charging time: 2 hours
  • Display: 96*16 OLED
  • Dimension Controller: 47mm/1.85 inch
  • Dimension Measuring arm: 106mm/4.17 inch
  • Operation: Hidden touch button
  • DT71 Controller x1
  • Test Arm x1
  • Tweezer Tip x2
  • Dedicated Data Cable x1
  • Carrying Case x1
  • Safety Instructions x1
  • FAQ
    Only 5 Left
