RJ45 Terminal Block Adapter - Horizontal
$11.90
SKU: FIT0852
  • $11.70 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
DIN Rail RJ45 Terminal Block Adapter simplifies wiring with an Ethernet jack and 8-port terminal block. Easy DIN rail installation for connecting sensors and displays.
DIN Rail RJ45 Terminal Block Adapter – Horizontal provides a practical solution for organizing Ethernet-based wiring in control cabinets and industrial installations. The DIN‑mountable RJ45 breakout adapter combines a standard RJ45 Ethernet socket with an eight‑position screw terminal interface, allowing each conductor inside a network cable to be individually accessed. This DIN rail networking adapter simplifies rapid prototyping, structured wiring, and hardware integration tasks by converting a typical RJ45 connection into clearly labeled terminal outputs. The compact terminal breakout board enables reliable signal routing for sensors, displays, embedded controllers, and other electronic subsystems used in automation and development environments.
Note: You need to use the bare network cable plug to plug in and out, and the press type will be blocked.
RJ45 Breakout for Fast Wiring Integration
This RJ45 terminal breakout module converts a standard eight‑core Ethernet connector into independent screw terminals, eliminating soldering requirements during wiring tasks. Each conductor from the RJ45 cable routes directly to a dedicated terminal block, allowing quick signal distribution or power routing. Such design significantly reduces wiring complexity when integrating sensors, displays, embedded boards, or communication devices. The clear terminal layout improves debugging efficiency while maintaining secure electrical connections suitable for development benches, control cabinets, and structured low‑voltage wiring systems.
DIN Rail Mounting for Industrial Enclosures
This DIN‑rail terminal adapter is designed for installation inside standard electrical cabinets using common DIN mounting systems. The enclosure integrates an RJ45 port and terminal block in a compact vertical layout, keeping wiring organized within automation panels and networking enclosures. The industrial‑style mounting approach improves installation efficiency while supporting stable mechanical fixation. Such a configuration makes the wiring breakout board suitable for industrial automation setups, structured cabling systems, and equipment racks where modular rail‑mounted hardware is preferred.
Figure: RJ45 Terminal Block Adapter
This Ethernet terminal breakout adapter supports rapid connection of sensors, display modules, embedded controllers, and other low‑voltage electronics that require structured cable routing. Such DIN‑mounted wiring hardware is particularly useful in industrial control systems, robotics platforms, prototyping benches, and educational electronics labs where quick access to individual RJ45 conductors simplifies integration and troubleshooting.
  • Simplifies complex Ethernet wiring by breaking out all eight RJ45 conductors
  • No soldering required with convenient screw terminal connections
  • DIN rail mounting design for control cabinets and equipment racks
  • Compact structure for organized industrial or prototype wiring setups
  • Sensor connection
  • Display power wiring
  • Microcontroller system integration
  • Color: Green
  • Interface: RJ45 eight-core interface
  • Material: PVC environment-friendly shell
  • Installation: DIN rail-mounted
  • Dimension: 90*35*53mm/ 3.54*1.38*2.09”
  • RJ45 Terminal Block Adapter - Horizontal x1
