This M12 to RJ45 Ethernet adapter uses M12 male 4 pin D coded with IP67 waterproof rating, which is impervious to dust and short-term soaking, safe and reliable to use.
There are metal shielding layers on the RJ45 port for fixing interface and preventing external electromagnetic interference, which assures good network signal. With pure copper eight-core gold-plated pins inside, the internal provides good contact and conduction performance during network data transmission.
The connector is fully compatible with the RJ45 network port, plug and play, which is very suitable for equipment with the same interface, such as industrial sensors, industrial cameras and switches.
