RJ45 Female to M12 4 Pin Male Adapter
$14.90
SKU: FIT0854
  • $14.60 3+ items
  • $14.30 5+ items
  • $13.80 10+ items
The M12 to RJ45 Ethernet adapter features IP67 waterproofing, metal shielding for signal integrity, and is suitable for industrial sensors and cameras.
RJ45 Female to M12 4 Pin Male Adapter provides a reliable bridge between standard Ethernet interfaces and rugged M12 industrial connectors. Featuring a D‑coded M12 male plug and a standard RJ45 female port, this industrial Ethernet adapter enables stable data connectivity in demanding environments. An IP67-rated enclosure protects internal conductors from dust and temporary immersion, supporting dependable operation in factory automation systems, machine vision setups, and industrial networking equipment. Durable materials, precision contacts, and shielded construction ensure consistent signal transmission for industrial sensors, cameras, and network switches deployed in harsh operating conditions.
Figure: RJ45 Female to M12 4 Pin Male Adapter
IP67-Rated Waterproof Industrial Connector
An IP67 waterproof rating allows this industrial Ethernet interface adapter to resist dust ingress and short-term immersion, ensuring stable networking performance in harsh environments. The sealed M12 connector structure enhances durability for factory automation, outdoor equipment, and machine installations where moisture, vibration, and contamination are common. Such protection helps maintain long-term electrical stability while safeguarding internal contacts from environmental damage during continuous industrial operation.
Shielded RJ45 Interface for Stable Signal Transmission
A metal shielding layer integrated around the RJ45 interface helps secure the connection while reducing external electromagnetic interference. This design supports stable Ethernet signal integrity in electrically noisy industrial environments. Inside the adapter, eight pure copper cores with gold‑plated contacts improve conductivity and ensure reliable contact performance during data transmission, helping maintain consistent communication between network devices and industrial control systems.
Figure: Shielded RJ45 interface and internal gold-plated contacts
Plug‑and‑Play Integration for Industrial Networking Equipment
Full compatibility with standard RJ45 Ethernet ports enables quick deployment without complex configuration. The M12-to-RJ45 networking adapter supports direct connection between industrial networking devices and equipment designed with M12 D‑coded connectors. Such compatibility simplifies wiring in automation systems, machine vision networks, and industrial monitoring infrastructure where robust circular connectors and conventional Ethernet ports must interoperate.
Figure: Adapter used for industrial equipment networking
This rugged industrial Ethernet conversion adapter suits a wide range of automation networking scenarios. Typical deployments include industrial sensors, machine vision cameras, and Ethernet switches requiring reliable M12 connectivity. Reliable sealing, shielded contacts, and plug‑and‑play compatibility make this networking connector accessory suitable for factory automation systems, industrial monitoring platforms, and other demanding Ethernet communication environments.
  • IP67 waterproof and dustproof industrial connector
  • Metal-shielded RJ45 interface reduces electromagnetic interference
  • Gold‑plated copper contacts ensure reliable conductivity
  • Plug‑and‑play compatibility with RJ45 Ethernet ports
  • Durable structure suitable for industrial networking environments
  • Industrial sensors
  • Industrial cameras
  • Industrial Ethernet switches
  • Factory automation systems
  • Machine vision networking
  • Color: Black
  • Interface: RJ45 Female to M12 4 Pin Male
  • Rated Current: 4A
  • Rated Voltage: AC 250V/DC 250V
  • Material: PVC environment-friendly shell
  • Insulation Resistance: ≥100MΩ
  • Contact Resistance: ≤3mΩ
  • IP Rating: IP67
  • Durability: ≥500 times
  • RJ45 Female To M12 4 Pin Male Adapter x1
  • RJ45 Female to M12 4 Pin Male Adapter
