Touchberry Pi 4B 10.1” Industrial Screen
$1010.00
SKU: DFR0910
10.1-inch capacitive touch screen with 1280x800 resolution, LVDS multi-touch, Ethernet, USB, WiFi, and supports Windows IoT for industrial use.
Purchase this product and earn 10100 reward points, which are tied to VIP membership program. Learn More >
The Raspberry Pi industrial screen is a 10.1-inch capacitive touch screen based on Raspberry Pi and packaged for the industrial environment using Linux. It supports Low Voltage Differential Signaling (LVDS) multi-touch, with a high resolution of 1280*800, and supports an output ratio of 16:9. It also has many built-in interfaces, such as Ethernet, USB, WiFi, and supports Windows IoT. Using the Ethernet port or WiFi network, you can remotely control all parameters, data, and inputs/outputs of the system.
Dimension Diagram of Raspberry Pi industrial screen
  • IoT Project
  • Industrial environment using Linux
  • Power supply voltage: 12~24Vdc
  • CPU: Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
  • GPU: Broadcom VideoCore VI
  • Operating System: Linux and Unix
  • Power consumption: 28W
  • Operating temperature: 0℃~40℃
  • Operating humidity: 10%~90% (no condensation)
  • Operating environment: Non-corrosive gas
  • Storage temperature: -20℃~60℃
  • Image resolution: 1280*800
  • Format: 16:9
  • Size: 10.1 inches
  • Touchberry Pi 4B 10.1”Industrial Screen x1
  • Only 2 Left
