M-DUINO PLC Arduino Ethernet 19R I/Os (Relay Output)
$355.00
SKU: DFR0905
The PLC device uses Arduino Mega2560 for professional control with 17 I/Os, supports remote programming via Ethernet, and allows expansion of up to 127 modules.
Purchase this product and earn 3550 reward points, which are tied to VIP membership program. Learn More >
This is the first PLC equipment based on the Arduino Technology designed for a professional use.
Taking Arduino Mega2560 as its core control chip, the M-Duino PLC has 17 I/Os including 4 analog and digital inputs, 2 interrupt isolated input, 3 analog outputs, 8 digital isolated relay outputs, and 3 PWM digital isolated outputs. Meanwhile, it contains several communicate ports like, UART, I2C, SPI, RS232, RS485, Ethernet, which provide more flexibility to control your device. Besides, the controller offers the possibility to expand up to 127 modules via I2C.
This PLC can be programmed using the Arduino IDE and supports remote programming through the Ethernet port. Also you can continuously monitor the status for all the variables, inputs, outputs, etc. It is compatible with the Ardbox, M-duino and the Touchberry Pi with an instantaneous connection.
Board Overview
  • With 17 I/O interfaces
  • Contains several communicate ports
  • Supports remote programming
  • Mode Type: M-Duino
  • Power Input Voltage: 12~24Vdc (Fuse Protection (2.5A) Polarity Protection)
  • Input Rated Voltage: 24Vdc
  • Rated Power: 30W
  • Max Current: 1.5A
  • Size: 101*701*119.5mm
  • Clock Speed: 16MHz
  • Flash Memory: 256kB of which 8kB for bootloader
  • SRAM: 8KB
  • EEPROM: 4KB
  • Communication: I2C, Ethernet, USB, RS485, RS232, SPI | (2x) Rx, Tx (Arduino pins) Max232-Max485-W5500
  • Operating Voltage Range: 11.4~25.4Vdc
  • Operating Temperature: 0℃~60℃
  • Operating Humidity: 10%~90% (No Condensation)
  • Operating Environment: No Corrosive Gas
  • Storage Temperature: -20℃~60℃
  • Analog Input Voltage: 0 ~ 10Vac
  • Digital Input Voltage: 7 ~ 24Vdc
  • Interrupt Input Voltage: 7~24Vdc
  • Expandability: I2C - 127 elements, serial port, RS485
  • Analog Output Voltage (8bit): 0 ~ 10Vac
  • M-DUINO PLC Arduino Ethernet 19R I/Os (Relay Output) x1
  • Only 5 Left
