M-DUINO 21 I/Os PLUS (Optoisolated Output)
$257.00
SKU: DFR0904
This PLC device integrates Arduino technology, offering 21 I/Os and various communication ports. It supports remote programming and module expansion.
Purchase this product and earn 2570 reward points, which are tied to VIP membership program. Learn More >
This is the first PLC equipment based on the Arduino Technology designed for a professional use.
Taking Arduino Mega2560 as its core control chip, the M-Duino PLC has 21 I/Os including 6 analog and digital inputs, 5 digital isolated inputs, 2 interrupt isolated inputs, 3 analog outputs, 5 digital isolated outputs, and 3 PWM isolated outputs. Meanwhile, it contains several communicate ports like, UART, I2C, SPI, RS232, RS485, Ethernet, which provide more flexibility to control your device. Besides, the controller offers the possibility to expand up to 127 modules via I2C.
This PLC can be programmed using the Arduino IDE and supports remote programming through the Ethernet port. Also you can continuously monitor the status for all the variables, inputs, outputs, etc. It is compatible with the Ardbox, M-duino and the Touchberry Pi with an instantaneous connection.
Board Overview
M-Duino 21 I/Os PLUS (Optoisolated Output)
  • With 21 I/O interfaces
  • Contains several communicate ports
  • Supports remote programming
  • Mode Type: M-Duino
  • Power Input Voltage: 12~24Vdc (Fuse Protection (2.5A) Polarity Protection)
  • Input Rated Voltage: 24Vdc
  • Rated Power: 30W
  • Max Current: 1.5A
  • Size: 101*701*119.5mm
  • Clock Speed: 16MHz
  • Flash Memory: 256kB of which 8kB used by bootloader)
  • SRAM: 8KB
  • EEPROM: 4KB
  • Communication: I2C, Ethernet, USB, RS485, RS232, SPI | (2x) Rx, Tx (Arduino pins) Max232-Max485-W5500
  • Operating Voltage Range: 11.4~25.4Vdc
  • Operating Temperature: 0℃~60℃
  • Operating Humidity: 10%~90% (No Condensation)
  • Operating Environment: No Corrosive Gas
  • Storage Temperature: -20℃~60℃
  • Analog Input Voltage: 0 ~ 10Vac
  • Digital Input Voltage: 7 ~ 24Vdc
  • Interrupt Input Voltage: 7~24Vdc
  • Expandability: I2C-127 elements, serial port, RS485
  • Analog Output Voltage (8bit): 0 ~ 10Vac
  • Digital Isolated Input Voltage: 5 ~ 24Vdc
  • M-DUINO 21 I/Os PLUS (Optoisolated Output) x1
  • Only 5 Left
