Spartan Arduino PLC 16RDA (Relay Output)
$150.00
SKU: DFR0903
Arduino-based PLC with 8 inputs, 6 relay outputs, easy USB programming, I2C communication for up to 127 modules, and versatile voltage and interface options.
Purchase this product and earn 1500 reward points, which are tied to VIP membership program. Learn More >
This Arduino-based Industrial PLC (Relay Output) features 8 inputs and 6 outputs(digital relay output).
As it uses an Arduino Leonardo, you can directly program it through the USB, which is pretty easy to get started. The Spartan controllers are all standarised and can be programmed exactly on the same way.
Moreover, the industrial controller offers the possibility of communication using I2C by a master-slave connection that can connect up to 127 modules. All the components are configurable.
Board Overview
  • With 8 inputs and 6 outputs
  • Standarised controller
  • Easy to programming
  • Mode Type: Spartan Arduino PLC 16RDA
  • Input / Supply Voltage: 12~24Vdc (Fuse Protection (2.5A) Polarity Protection)
  • Input Rated Voltage: 24Vdc
  • Rated Power: 30W
  • Max Current: 1.5A
  • Size: 100 * 45 * 115 mm
  • Clock Speed: 16MHz
  • Flash Memory: 32kB of which 4kB used by bootloader)
  • SRAM: 2.5KB
  • EEPROM: 1KB
  • Communication Interface: I2C, USB, RS485 (HD), SPI, TTL
  • Operating Voltage Range: 11.4~25.4Vdc
  • Operating Temperature: 0℃~60℃
  • Operating Humidity: 10%~90% (No Condensation)
  • Operating Environment: No Corrosive Gas
  • Storage Temperature: -20℃~60℃
  • Analog Input Voltage: 0 ~ 10Vac
  • Digital Input Voltage: 5 ~ 24Vdc
  • Interrupt Input Voltage: 5~24Vdc
  • Expandability: I2C-127 elements, serial port, RS485
  • Spartan Arduino PLC 16RDA (Relay Output) x1
  • Only 3 Left
