NPN to PNP Signal Converter / Adapter Module
$10.00
SKU: FIT0850
  • $9.70 3+ items
  • $9.50 5+ items
  • $9.20 10+ items
This module converts NPN signals to PNP, featuring surge absorption and over-current protection. It operates at 5-24V DC with a maximum load current of 100mA.
Purchase this product and earn 100 reward points, which are tied to VIP membership program. Learn More >
If sensors are used in your equipment or control systems, having these signal converter modules like this NPN to PNP converter readily available could effectively eliminate the last-minute problems that you encounter when your controller and the type of sensor you are using have a mismatched signal.
This signal converter is designed to convert NPN signal to PNP and is equipped with surge absorption and over-current protection to further protect your device.
Adapter from NPN to PNP
Pinout
Connection Diagram
  • Working Voltage: 5~24V DC
  • Current Protection: Overcurrent protection, surge absorption
  • Load Current: 100mA max
  • Operating Temperature: -20℃~70℃
  • Operating Humidity: 35~85%RH
  • Response Time: 1us
  • Model: BM-NP
  • Conversion: NPN.NO-PNP.NO
  • NPN to PNP Converter x1
  • Wire Connector x1
