4-Pin LED Strip Connector (5PCS) provides a quick, reliable way to join cuttable RGB LED strip segments without soldering. Designed for 10 mm wide 4-wire LED strips, this compact strip-to-strip connector enables clean lighting installations while reducing assembly time. A snap‑down locking structure ensures stable electrical contact across all four channels, making the accessory suitable for decorative lighting builds, prototype lighting systems, and modular LED projects. This solderless RGB strip coupler simplifies extension or repair of flexible LED strips while maintaining consistent current delivery up to 5A.
Figure: Product assembly
Tool‑Free RGB LED Strip Connection
This solderless LED strip coupler eliminates the need for soldering tools when joining two RGB strip segments. A simple alignment and press‑down installation method securely grips exposed copper pads on compatible 10 mm wide 4‑pin LED strips. Such a quick‑connect lighting accessory helps accelerate LED installation work in decorative lighting layouts, prototype builds, and lighting repairs where traditional solder joints would otherwise increase complexity and assembly time.
Secure Snap‑Down Electrical Contact
A reinforced snap‑down locking mechanism forms a firm mechanical hold and stable electrical pathway across all four RGB channels. The compact connector structure supports LED strip thickness between 0.2 mm and 0.4 mm while carrying up to 5 A of current, allowing reliable operation in most low‑voltage RGB lighting systems. Durable materials and a wide operating temperature range support stable performance across indoor decorative lighting installations and continuous LED strip operation.
Figure: Product dimension
Suitable for RGB LED lighting extensions, decorative installations, and LED strip repairs, this quick‑install lighting connector supports efficient modular lighting assembly without soldering equipment. The compact RGB strip joiner enables clean cable management and convenient strip replacement in DIY lighting projects, display lighting setups, and general LED decoration systems.
