4-Pin LED Strip Connector Cable-Single Head (5PCS)
$2.90
SKU: FIT0866
  • $2.80 3+ items
  • $2.70 5+ items
  • $2.60 10+ items
Solderless LED strip connector with a snap-down design, 20cm DuPont-style wire. Features clearly marked polarity, suitable for 10mm wide, 4-pin strips.
Is there a way to join two pieces of cuttable LED strips together without soldering? Yes, there is.
This 4-Pin solderless LED strip connector comes with 20cm wire connected to a DuPont-style female connector, and the other end employs snap-down design that makes a firm connection.
Besides, the clearly marked polarity and color-labeled wires make it very convenient to use.
4Pin LED Strip Connector Cable-Single Head (5Pcs)
  • Clearly marked polarity
  • Color-labeled wires
  • Lighting Decoration
  • Suitable LED Strip Width: 10mm
  • Wire Length: 20cm
  • For 4-Pin LED strip
  • DuPont Connector
  • Current: Max 5A
  • Operating Temperature: -45℃~+105℃
  • Wire: 22AWG, UL certificated
  • Suitable LED Strip Thickness: 0.2mm-0.3mm
  • 4-Pin LED Strip Connector Cable-Single Head (5PCS) x1
  • Out Of Stock
