Beetle CM-32U4 - Compatible with Arduino Leonardo - ATmega32U4
$8.90
SKU: DFR0816
  • $8.80 3+ items
  • $8.60 5+ items
  • $8.30 10+ items
The microcontroller features compact size, onboard charging, and standard communication interfaces, ideal for Arduino projects with various power supply options.
Beetle CM-32U4 is a micro Leonardo controller with an onboard charging chip.
As an upgraded version of the DFRobot Beetle Board, this board is greatly optimized in integration and usability, which makes it well applicable to Arduino projects that require compact size and long service life.
Just like the Beetle series, despite a mini body, it has powerful functionalities. On a size of only 22mm*20.5mm, Beetle CM-32U includes most commonly-used communication interfaces: 1×I2C, 1×SPI, 1×UART, 2×analog Interface, 2×digital interface, 2×GND reserved and 1×5V output, which are all designed as pin connector form, more intuitive and easy to use compared with the onboard pads of Beetle. Besides, Beetle CM-32U4 supports official Leonardo firmware, which means you can directly use it in Arduino IDE without extra download.
Overview of Beetle CM-32U4 - Compatible with Arduino Leonardo - ATmega32U4
It integrates the charging management function for Lithium battery. You can easily connect the battery to the board via pins, which could reduce project building difficulty, meanwhile, much smaller and safer.
There are 3 power supply methods: USB power supply; Battery pack power supply on the BAT pin; 5V external power supply on the VIN pin, making this board more widely applicable to DIY projects, workshops, gift projects, E-Textiles wearable, and educational. And the features of rechargeable and diverse power supplies, to some extent, are equivalent to "uninterrupted power supply (UPS)".
Beetle CM-32U4
Board Overview
  • Rich functions
  • Small size
  • Greatly increase the service life
  • DIY projects
  • Workshops
  • Gift projects
  • E-Textiles wearable
  • Applications of Beetle CM-32U4 - Compatible with Arduino Leonardo - ATmega32U4
  • Operating Voltage: 5V DC
  • Maximum Charging Current: 600mA
  • Minimum Charging Current: 200mA
  • Operating Temperature Range: -40~125℃
  • Interface: I2C x 1,SPI x 1,UART x 1,Analog x 2,Digital x 2
  • Dimension: 22 x 20.5mm/0.87 x 0.81”
  • Beetle CM-32U4 x1
  • 8pin-2.54mm Pin Header x2
    Lightning Bot / Sensor
    Projects Lightning Bot / Sensor
    KGray
    Aug 25, 2021
    Chaos Gift Build: Moving House & Making a Toilet Talk
    Projects Chaos Gift Build: Moving House & Making a Toilet Talk
    Mellow_Labs
    Jul 14, 2025
    Beetle Controller Selection Guide
    Blog Beetle Controller Selection Guide
    Mar 30, 2022
    Ionizing Radiation Detector
    Projects Ionizing Radiation Detector
    KGray
    Jun 25, 2024
    Make a TINY Arduino Drone with FPV Camera - Will It Fly?
    Tutorial Make a TINY Arduino Drone with FPV Camera - Will It Fly?
    Max Imagination
    Apr 20, 2024
    DIY Precise Arduino Anemometer with Linear Led Scale - DFRobot
    Projects DIY Precise Arduino Anemometer with Linear Led Scale - DFRobot
    mircemk
    Feb 15, 2022
    Chris.Stansell Apr 29, 2025
    I've used this microcontroller 40 times now. With more uses planned in the future. Absolutely amazing performance and so easy to set up.
