Fermion: Serial Data Logger V2.0 for Arduino
$5.90
SKU: TEL0148
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
The Serial Data Logger supports 32GB cards, USB connection, direct serial data printing, and TXT/CSV formats. Ideal for offline data collection and debugging.
Compared to the previous MicroSD Card Module, this Fermion: Serial Data Logger can store data more conveniently, and supports direct data printing through serial port without additional codes.
The Serial Data Logger supports 32GB TF card, making it suitable for long-time data storage. It comes with a USB function, which means you can directly connect it to a PC to read the stored files without using a card reader. Meanwhile, with the onboard LED indicator, data writing status can be viewed visually. And the onboard SAVE pin makes it easier to store data into separate files.
Note: Due to the varying quality of SD cards available on the market, compatibility with all SD cards cannot be guaranteed. It is recommended to purchase SD cards from the following link.
SD/MicroSD Memory Card 16G
SD/MicroSD Memory Card 32G
The upgraded V2.0 version compared to V1.0 version:
  • Supports storage in TXT and CSV file formats.
  • Significantly improves startup time and runtime stability.
  • Supports scheduled creation of files for more flexible storage.
  • Added USB port to make reading files more convenient.
  • Fermion: Serial Data Logger
    Connection Diagram
    Pinout
  • With USB function, no card reader required
  • Support multiple baud rates, with good compatibility
  • LED indicator for viewing data writing status visually
  • FAT32 file system, support 32GB TF card
  • Offline data collection
  • Capture product debug logs
  • Robots and drones debug
  • Supply Voltage: 3.3V~5V
  • Operating Current: 10mA
  • USB Protocol: USB2.0
  • Operating Temperature Range: -20℃~65℃
  • Operating Humidity Range: 5%RH~85%RH
  • Dimension: 23*29mm/0.91*1.14”
  • Fermion: Serial Data Logger x1
  • 2.54-10P Black Single-row Connector x1
  • FAQ
    Out Of Stock
