The DC-DC boost-buck converter is a versatile power regulation device designed to address the need for stable output voltage across various input voltages. This product ensures consistent power delivery with automatic voltage regulation, achieving a conversion efficiency of up to 89% and a maximum output current of 5A. Ideal for industrial power supplies, DIY smart power supplies, and embedded system power applications, this converter excels in maintaining stable voltage in diverse scenarios.
Automatic Voltage Regulation
The DC-DC boost-buck converter features automatic voltage regulation, which allows the input voltage to be either higher or lower than the desired output voltage while maintaining a stable output. This flexibility makes it highly adaptable to different power requirements and input conditions.
High Conversion Efficiency, up to 90%
With a conversion efficiency of up to 90%, the converter ensures minimal energy loss during voltage regulation. This efficiency is particularly evident when the input voltage is 12V and the output is 19V/2.5A, though actual efficiency may vary based on specific input and output parameters.
Maximum Output Current 5A
Capable of delivering a maximum output current of 5A, this converter is suitable for high-demand applications. Users should consider appropriate heat dissipation measures when operating at high power to prevent overheating and ensure stable performance.
1. Input+
2. Input-
3. Output+
4. Output-
5. Output Indicator
6. Output Voltage Regulation
Feb 01, 2024
This is a very good performance part - Really great for using with a LiPo or LiIon battery for your 5V projects with needs power such as RPi.
