This push-in 1-in 3-out wire connector can easily turn one input connection into 3 output connections. It features firm wiring, recyclability, flame retardant, and fire resistance. The conductive spring clamp inside the connector is made of nickel-coated steel, which is anti-corrosion, tight, not easy to loosen or fall off.
Dimension
Electrical Parameters
Connector Parameters
Material Specifications
