Gravity: 3 Pin PH2.0 to DuPont Male Connector Digital Cable Pack (30cm)
$6.00
SKU: FIT0896
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
30cm digital sensor cables with PH2.0 and Dupont connectors, color-labeled for easy identification, compatible with breadboards; package includes 10 cables.
Purchase this product and earn 60 reward points, which are tied to VIP membership program. Learn More >
Note: One package has 10 cables.
This high-quality 30cm digital sensor cable is equipped with 3 pin PH2.0 plug connector on one side and Dupont male connector on the other side.
One package has 10 cables. Compatible with breadboard and DuPont wire spacing, these cables use materials that are in line with RoHS requirements. It’s color labeled, which is convenient for distinguishing the sensor output type and wiring in the production project.
They are specially designed for our popular IO Expansion shield and digital sensors such as vibration sensors, tilt sensors, magnetic induction, etc.
It connects most of our digital sensors to the IO board, making it convenient to make interesting interactive works.
Gravity: PH2.0 to DuPont Male Connector Digital Cable (30cm)
  • Compatible with breadboard and DuPont wire spacing
  • Color labeled, convenient for distinguishing
  • Connect digital sensors to the IO board
  • Withstand Voltage: <50V
  • Withstand Current: <1000mA
  • Length: 30cm
  • Interface: 3Pin PH2.0-DuPont Male
  • Black Wire: Power -
  • Red Wire: Power +
  • Green Wire: Digital signal
  • Gravity: 3 Pin PH2.0 to DuPont Male Connector Digital Cable (30cm) x10
  • Gravity: 3 Pin PH2.0 to DuPont Male Connector Digital Cable Pack (30cm)
