Gravity: 3 Pin PH2.0 to DuPont Male Connector Analog Cable Pack (30cm)
$6.00
SKU: FIT0897
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
A package includes ten 30cm cables with 3-pin PH2.0 to DuPont male connectors, ideal for analog sensors and IO boards. They are color-coded for easy use.
Purchase this product and earn 60 reward points, which are tied to VIP membership program. Learn More >
Note: One package has 10 cables.
This high-quality 30cm analog sensor cable is equipped with 3-pin PH2.0 plug connector on one side and Dupont male connector on the other side.
Compatible with breadboard and DuPont wire spacing, these cables use materials that are in line with RoHS requirements. It’s color labeled, which is convenient for distinguishing the sensor output type and wiring in the production project.
They are specially designed for our popular IO Expansion shield and analog sensors such as Ambient light sensor, Gray sensor, MIC sound, etc.
It connects most of our analog sensors to the IO board, making it convenient to make interesting interactive works.
  • Compatible with breadboard and DuPont wire spacing
  • Color labeled, convenient for distinguishing
  • Connect digital sensors to the IO board
  • Withstand Voltage: <50V
  • Withstand Current: <1000mA
  • Length: 30cm
  • Interface: 3Pin PH2.0-DuPont male
  • Black Wire: Power-
  • Red Wire: Power +
  • Blue Wire: Analog signal
  • Gravity: 3 Pin PH2.0 to DuPont Male Connector Analog Cable Pack (30cm) x10
  • Review
    Sven.Sven Jan 08, 2025
