Fermion: 1.8" 128x160 IPS TFT LCD Display with MicroSD Card Slot (Breakout)
$7.90
SKU: DFR0928
  • $7.70 3+ items
  • $7.60 5+ items
  • $7.40 10+ items
1.8" TFT display with 128×160 resolution, SPI communication, SD card slot, supports various wiring methods, ideal for sensor monitoring and Arduino projects.
This ST7735S 1.8" TFT Display features a resolution of 128×160 and SPI (4-wire) communication. Integrated with an SD card slot, it allows to easily read full-color bitmaps from the SD card.
The module provides users with two wiring methods: pin header wiring and GDI (General Display interface). You can directly connect the display to a FireBeetle main controller using an FPC cable. Plug and play, easy to wire. Besides, the display supports a low refresh rate and offers a good display effect and strong versatility.
It can be used in applications like sensor monitoring and alarm, Arduino temperature monitor, fan controller, etc.
Fermion: 1.8
Connect Diagram
Fermion: 1.8
  • 128x160 Resolution
  • SPI (4-wire) communication
  • Integrated with an SD card slot
  • Sensor monitoring and alarm
  • Arduino temperature monitor
  • Fan controller
  • Operating Voltage: 3.3 V - 5 V
  • TFT Viewing Angle: 120 degrees
  • Pixels: 128 columns x 160 rows
  • Communication: SPI
  • Interface Mode: GDI, pin header
  • Driver Chip: ST7735S
  • Full-screen Power Consumption: 0.11 W
  • MicroSD Slot x 1
  • Operating Temperature: -10℃ - +60℃
  • Display Area: 26 mm x 35 mm/1.02x1.38"
  • Module Dimension: 34 mm x 55 mm/1.34x2.17"
  • Mounting Hole Pitch: 29 mm/1.14", 50 mm/1.97"
  • Mounting Hole Size: 2 mm/0.08"
  • Fermion: 1.8" 128x160 IPS TFT LCD Display with MicroSD Card Slot (Breakout) x1
  • GDI Display Cable x1
  • 10P Pin Connector x1
  • FAQ
    jérémi.darien May 10, 2025
    This is an amazing product
