ESP32-S3-WROOM-1 AIoT WiFi & BLE 5 MCU Module (PCB Antenna)
$3.50
SKU: DFR0896
A versatile Wi-Fi and Bluetooth module for AIoT applications, featuring dual-core processor, multiple peripherals, 4MB flash, and supports face/speech recognition.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
The ESP32-S3-WROOM-1 is a generic Wi-Fi and Bluetooth LE MCU module designed for a wide range of applications. It is based on the ESP32-S3 SoC, featuring a Xtensa® dual-core 32-bit LX7 microprocessor with a clock frequency up to 240 MHz and AI acceleration capabilities. This variant (N4) includes 4 MB of SPI flash, 512 KB SRAM, and 16 KB RTC SRAM. It supports Wi-Fi (802.11 b/g/n) and Bluetooth 5 (LE) with an onboard PCB antenna. Peripherals include SPI, LCD, Camera interface, UART, I2C, I2S, USB OTG, ADC, and up to 36 GPIOs.
ESP32-S3 integrates multiple peripherals including SPI, LCD, Camera interface, UART, I2C, I2S, IR remote control, pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, SDIO host, GDMA, TWAI® controller (compatible with ISO 11898-1), ADC, touch sensor, temperature sensor, timers, and watchdogs, as well as up to 36 GPIOs. And it also includes a full-speed USB 1.1 On-The-Go (OTG) interface to enable USB communication.
ESP32-S3-WROOM-1-N4 Module (PCB Antenna)
Pinout
Pin Definitions
Name NO. Typea Function
GND 1 P GND
3V3 2 P Power supply
EN 3 I High level: on, enables the chip
Low level: off, the chip powers off
Note: Do not leave the EN pin floating
IO4 4 I/O/T RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3
IO5 5 I/O/T RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4
IO6 6 I/O/T RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5
IO7 7 I/O/T RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6
IO15 8 I/O/T RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P
IO16 9 I/O/T RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N
IO17 10 I/O/T RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6
IO18 11 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3
IO8 12 I/O/T RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1
IO19 13 I/O/T RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D-
IO20 14 I/O/T RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+
IO3 15 I/O/T RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2
IO46 16 I/O/T GPIO46
IO9 17 I/O/T RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD, SUBSPIHD
IO10 18 I/O/T RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4, SUBSPICS0
IO11 19 I/O/T RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5, SUBSPID
IO12 20 I/O/T RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6, SUBSPICLK
IO13 21 I/O/T RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7, SUBSPIQ
IO14 22 I/O/T RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS, SUBSPIWP
IO21 23 I/O/T RTC_GPIO21, GPIO21
IO47 24 I/O/T SPICLK_P_DIFF, GPIO47, SUBSPICLK_P_DIFF
IO48 25 I/O/T SPICLK_N_DIFF, GPIO48, SUBSPICLK_N_DIFF
IO45 26 I/O/T GPIO45
IO0 27 I/O/T RTC_GPIO0, GPIO0
IO35b 28 I/O/T SPIIO6, GPIO35, FSPID, SUBSPID
IO36b 29 I/O/T SPIIO7, GPIO36, FSPICLK, SUBSPICLK
IO37b 30 I/O/T SPIDQS, GPIO37, FSPIQ, SUBSPIQ
IO38 31 I/O/T GPIO38, FSPIWP, SUBSPIWP
IO39 32 I/O/T MTCK, GPIO39, CLK_OUT3, SUBSPICS1
IO40 33 I/O/T MTDO, GPIO40, CLK_OUT2
IO41 34 I/O/T MTDI, GPIO41, CLK_OUT1
IO42 35 I/O/T MTMS, GPIO42
RXD0 36 I/O/T U0RXD, GPIO44, CLK_OUT2
TXD0 37 I/O/T U0TXD, GPIO43, CLK_OUT1
IO2 38 I/O/T RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1
IO1 39 I/O/T RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0
GND 40 P GND
EPAD 41 P GND
  • P: power supply; I: input; O: output; T: can be set to high impedance. Pin functions in bold font are the default ones. The default functions of pins 28 ~ 30 are determined by the eFuse bit.
  • In modules that have embedded OSPI PSRAM (i.e., that embed ESP32-S3R8), pins IO35, IO36, and IO37 are used to connect to the OSPI PSRAM and not available for other uses.
  • Features
  • Powerful and generic Wi-Fi and Bluetooth
  • Integrates multiple peripherals
  • Wake word detection
  • Speech commands recognition
  • Face detection and recognition
  • Smart home
  • Smart appliances
  • Smart control panel
  • Smart speaker
  • ESP32-S3 series of SoCs embedded, Xtensa® dual-core 32-bit LX7 microprocessor (support single-precision floating-point units), support the clock frequency of up to 240MHz
  • 384 KB ROM
  • 512 KB SRAM
  • 16 KB RTC SRAM
  • 4 MB SPI flash
  • Bluetooth LE: Bluetooth 5, Bluetooth mesh
  • 40MHz crystal oscillator
  • Module Dimension: 18x25.5x3.1(mm)/0.71x1.00x0.12(inches)
  • Operating Temperature: –40~85℃
  • ESP32-S3-WROOM-1-N4 Module (PCB Antenna) x1
  • Only 19 Left
