The ESP32-S3-WROOM-1 is a generic Wi-Fi and Bluetooth LE MCU module designed for a wide range of applications. It is based on the ESP32-S3 SoC, featuring a Xtensa® dual-core 32-bit LX7 microprocessor with a clock frequency up to 240 MHz and AI acceleration capabilities. This variant (N4) includes 4 MB of SPI flash, 512 KB SRAM, and 16 KB RTC SRAM. It supports Wi-Fi (802.11 b/g/n) and Bluetooth 5 (LE) with an onboard PCB antenna. Peripherals include SPI, LCD, Camera interface, UART, I2C, I2S, USB OTG, ADC, and up to 36 GPIOs.
ESP32-S3 integrates multiple peripherals including SPI, LCD, Camera interface, UART, I2C, I2S, IR remote control, pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, SDIO host, GDMA, TWAI® controller (compatible with ISO 11898-1), ADC, touch sensor, temperature sensor, timers, and watchdogs, as well as up to 36 GPIOs. And it also includes a full-speed USB 1.1 On-The-Go (OTG) interface to enable USB communication.
Pinout
Pin Definitions
Name | NO. | Typea | Function |
GND | 1 | P | GND |
3V3 | 2 | P | Power supply |
EN | 3 | I | High level: on, enables the chip |
Low level: off, the chip powers off | |||
Note: Do not leave the EN pin floating | |||
IO4 | 4 | I/O/T | RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3 |
IO5 | 5 | I/O/T | RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4 |
IO6 | 6 | I/O/T | RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5 |
IO7 | 7 | I/O/T | RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6 |
IO15 | 8 | I/O/T | RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P |
IO16 | 9 | I/O/T | RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N |
IO17 | 10 | I/O/T | RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6 |
IO18 | 11 | I/O/T | RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3 |
IO8 | 12 | I/O/T | RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1 |
IO19 | 13 | I/O/T | RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D- |
IO20 | 14 | I/O/T | RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+ |
IO3 | 15 | I/O/T | RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2 |
IO46 | 16 | I/O/T | GPIO46 |
IO9 | 17 | I/O/T | RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD, SUBSPIHD |
IO10 | 18 | I/O/T | RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4, SUBSPICS0 |
IO11 | 19 | I/O/T | RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5, SUBSPID |
IO12 | 20 | I/O/T | RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6, SUBSPICLK |
IO13 | 21 | I/O/T | RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7, SUBSPIQ |
IO14 | 22 | I/O/T | RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS, SUBSPIWP |
IO21 | 23 | I/O/T | RTC_GPIO21, GPIO21 |
IO47 | 24 | I/O/T | SPICLK_P_DIFF, GPIO47, SUBSPICLK_P_DIFF |
IO48 | 25 | I/O/T | SPICLK_N_DIFF, GPIO48, SUBSPICLK_N_DIFF |
IO45 | 26 | I/O/T | GPIO45 |
IO0 | 27 | I/O/T | RTC_GPIO0, GPIO0 |
IO35b | 28 | I/O/T | SPIIO6, GPIO35, FSPID, SUBSPID |
IO36b | 29 | I/O/T | SPIIO7, GPIO36, FSPICLK, SUBSPICLK |
IO37b | 30 | I/O/T | SPIDQS, GPIO37, FSPIQ, SUBSPIQ |
IO38 | 31 | I/O/T | GPIO38, FSPIWP, SUBSPIWP |
IO39 | 32 | I/O/T | MTCK, GPIO39, CLK_OUT3, SUBSPICS1 |
IO40 | 33 | I/O/T | MTDO, GPIO40, CLK_OUT2 |
IO41 | 34 | I/O/T | MTDI, GPIO41, CLK_OUT1 |
IO42 | 35 | I/O/T | MTMS, GPIO42 |
RXD0 | 36 | I/O/T | U0RXD, GPIO44, CLK_OUT2 |
TXD0 | 37 | I/O/T | U0TXD, GPIO43, CLK_OUT1 |
IO2 | 38 | I/O/T | RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1 |
IO1 | 39 | I/O/T | RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0 |
GND | 40 | P | GND |
EPAD | 41 | P | GND |
