Solar Power Manager with Panel (9V)
$46.80
SKU: DFR0535-1
The kit offers a solar power manager with MPPT for efficiency, supporting 9V/12V/18V panels, and a 9V 220mA solar panel, ideal for IoT and low-power projects.
Purchase this product and earn 325 reward points, which are tied to VIP membership program. Learn More >
DFRobot Solar Power Manager Kit combines the Solar Power Manager (for 9V/12V/18V solar panel) with a compact Solar Panel (9V 220mA), forming a ready-to-deploy renewable power solution for embedded electronics and IoT devices. Designed for efficient off‑grid operation, this solar energy management system integrates MPPT technology, battery charging control, and multiple regulated outputs on a single board. The solar power controller supports direct solar input, USB charging, or AC adapter power while managing a 3.7V lithium battery. Integrated DC‑DC regulators provide stable voltage rails for microcontrollers, sensors, and wireless modules, making the platform well suited for compact autonomous systems.
High‑Efficiency MPPT Solar Energy Harvesting
A constant‑voltage MPPT (Maximum Power Point Tracking) algorithm maximizes energy extraction from connected photovoltaic panels. This solar power management module dynamically optimizes the operating point of the solar input, ensuring higher conversion efficiency compared with conventional charging circuits. Wide 7V–30V solar input support enables compatibility with multiple panel types while maintaining efficient battery charging performance for low‑power electronics deployed in outdoor or remote environments.
Integrated Multi‑Output Power Distribution
This embedded solar controller board integrates three independently switchable DC‑DC converters, delivering regulated outputs of 5V 1.5A, 3.3V 1A, and 9V/12V 0.5A. Such flexible voltage rails simplify power architecture for IoT nodes, robotics electronics, and environmental monitoring platforms. Individual ON/OFF control further improves energy efficiency in battery‑powered deployments by allowing selective power delivery to connected subsystems.
Flexible Charging with Comprehensive Protection
Beyond solar charging, the renewable energy management board accepts USB or AC adapter input (up to 30V) with a maximum 2A charge current for 3.7V lithium batteries. Multiple safety protections improve system reliability, including battery over‑charge, over‑discharge, over‑current protection, solar reverse polarity protection, and output short‑circuit or thermal protection. MLCC capacitor design contributes to stable operation and improved electrical efficiency in long‑term installations.
DFR0535-Solar Power Manager Board Overview
Figure: Solar Power Manager
DFR0535-Build a solar powered system
Figure: Build a solar powered system
Such a solar energy kit supports a wide range of renewable power applications including smart environmental monitoring stations, solar‑powered robotics, compact street lighting systems, and portable solar charging devices. The integrated solar panel and management board provide a convenient platform for building stable low‑power systems powered entirely by sunlight.
  • Constant voltage MPPT algorithm, maximizing solar panel efficiency
  • 7V~30V wide solar panel input voltage
  • Various charging mode: solar/AC adapter/USB charger (2A max charge current)
  • Three individual ON/OFF controllable regulated power supply for low-power applications
  • All multi-layer ceramic capacitors (MLCC), safe, stable and high-efficiency
  • Various protection functions
  • USB connector with ESD shell
  • Smart solar environment monitor system
  • Solar-powered robot
  • Small solar street lamp
  • Solar power bank
  • Solar power management IC: LTC3652
  • Solar input voltage (SOLAR IN): 7V~30V
  • Battery input (BAT IN): 3.7V single-cell Li-polymer/Li-ion battery
  • Charge current(USB/SOLAR IN): 2A Max
  • Charging cutoff voltage(USB/SOLAR IN): 4.2V±1%
  • MPPT setting voltages: OFF/9V/12V/18V
  • USB IN voltage: 5V
  • Regulated power supply: OUT1=5V 1.5A; OUT2=3.3V 1A; OUT3=9V/12V 0.5A
  • Regulated power supply efficiency (3.7V battery IN)
    OUT1: 86%@50%Load
    OUT2: 92%@50%Load
    OUT3 (9V OUT): 89%@50%Load
  • USB charge efficiency: 84%@1A
  • Solar charge efficiency (18V SOLAR IN):78%@1A
  • Maximum quiescent current: <3 mA
  • Protections
    BAT IN: over charge /over-discharge /over current /reverse connection protection
    OUT1-OUT3/USB OUT: short circuit/over current/overheat protection
    SOLAR IN: reverse connection protection
  • Operation temperature:-40℃~85℃
  • Dimension:78.0mm*68.0mm
  • Solar Power Manager x1
  • Black Jumper x3
  • M3 nylon pillar x4
  • M3 stainless steel screw x4
  • 14mm*14mm Aluminum cooling fin x1
  • 14mm*14mm Thermal conductive silicone pad x1
  • Female DC power jack adapter x1
  • Solar Panel (9V 220mA) x1
  • Out Of Stock
