4 Cell AA Battery Holder with 5-inch tinned leads provides a compact and reliable power supply solution for electronics projects requiring portable battery power. This square‑layout battery case accommodates four standard AA batteries to deliver stable voltage for embedded systems, robotics prototypes, and educational electronics builds. Durable plastic construction secures batteries firmly while exposed tinned wire leads allow quick soldering or direct connection to power inputs on development boards and custom circuits. As a practical power accessory for prototyping environments, this AA battery pack simplifies rapid deployment of battery‑powered hardware without complex wiring or additional connectors.
Square Configuration for Compact Integration
A square battery arrangement minimizes footprint compared with long inline battery trays, allowing easier integration inside enclosures, robotic chassis, and portable electronic housings. This compact four‑AA battery case distributes cells in a balanced layout that fits efficiently within space‑constrained prototypes. Makers building mobile robots, handheld instruments, or portable sensor nodes benefit from simplified mechanical placement while maintaining reliable battery alignment and secure electrical contact for consistent power delivery.
Pre‑Tinned Leads for Fast Electrical Connection
Two 5‑inch pre‑tinned wire leads enable straightforward soldering to power rails, terminal blocks, or custom circuit boards. This wired battery holder eliminates the need for additional connectors and speeds up assembly during prototyping and educational electronics projects. Tinned wire ends improve solderability and ensure strong electrical joints, making this compact battery power module well suited for quick experimental builds, classroom electronics kits, and rapid hardware iteration.
Portable electronics, small robotics platforms, and embedded development projects often require simple battery solutions for untethered operation. This four‑AA battery supply module serves as a dependable power source for microcontroller prototypes, DIY gadgets, and STEM learning activities, delivering convenient battery integration for a wide range of low‑voltage electronic systems.
Basic Parameters
