Discontinued
This digital I2S MEMS Microphone works well with microcontrollers with I2S audio outputs like ESP32. Compared with traditional analog ones, this microphone features low noise, high sensitivity & reliability, and other excellent performances, which make it applicable to projects like voice recognition, recording, AI learning, Bluetooth audio transmission, and so on.
This module uses surface mount MEMS I2S microphone sensor with top port, no components at the bottom, which can be embedded into various applications conveniently. Besides, DFRobot provides users with Arduino library for this product to allow them easily get started on ESP32.
Connection Diagram
Jul 01, 2025
The form factor... Oh man. You can just add pins, then drop them right onto most ESP32s from one of the corners. All of the pins will line up perfectly! No need for a PCB boardbreakout when you're doing this. Very durable.
Feb 17, 2025
I haven't yet tested it, but it came well packaged and in good condition.
Jan 06, 2025
Fermion: I2S MEMS Microphone (Breakout) Easy to use with any Esp32. Thank you DF.
