SIM7600G-H-M2 4G Communication Module
$48.90
SKU: TEL0158
  • $48.00 3+ items
  • $47.00 5+ items
  • $45.00 10+ items
The LTE Cat 4 module supports multiple wireless modes with up to 150Mbps downlink. It integrates GNSS systems, has versatile interfaces, and suits IoT applications.
Purchase this product and earn 489 reward points, which are tied to VIP membership program. Learn More >
The SIM7600G-H-M2 is the LTE Cat 4 module that supports wireless communication modes of LTE-TDD, LTE-FDD, HSPA+, GSM, GPRS, EDGE, etc. It supports maximum 150Mbps downlink rate and 50Mbps uplink rate.
The SIM7600G-H-M2 adopts M.2 form factor and M.2 B KEY interface and consists of a SIM7600-H module and a M.2 adapter board. It is easy for customers to integrate. The module integrates multiple satellite high-accuracy positioning GNSS systems with multiple built-in network protocols, which is suitable for LTE, UMTS, and GSM networks with global coverage and supports drivers for main operation systems(Windows, Linux, and Android, etc.) and software functions like FOTA, LBS, TLS, etc. Users can debug the module via AT commands of all kinds.
Meanwhile, the SIM7600G-H-M.2 integrates mainstream industrial standard interfaces, with powerful expansibility, including abundant interfaces such as UART, USB, and GPIO, which is suitable for main IoT applications such as telematics, surveillance devices, CPE, industrial routers, and remote diagnostics, etc.
  • Supports maximum 150Mbps downlink rate and 50Mbps uplink rate
  • Integrates mainstream industrial standard interfaces
  • Telematics
  • Surveillance devices
  • CPE
  • Industrial routers
  • Remote diagnostics
    Frequency Band
  • LTE-FDD: BI, B2, B3, B4, B5, B7, B8, B12, BI3, B18, B19, B20, B25, B26, B28, B66
  • LTE-TDD: B34, B38, B39, B40, B41
  • WCDMA: BI, B2, B4, B5, B6, B8, B19
  • GSM: 850, 900, 1800, 1900MHz
  • GNSS: GPS, Beidou, GLONASS, GALILEO, QZSS
  • Data Transfer
  • LTE: 150 Mbps (DL) / 50 Mbps (UL)
  • HSPA+: 42 Mbps (DL) / 5.76 Mbps (UL)
  • WCDMA: 384 Kbps (DL) / 384 Kbps (UL)
  • EDGE: 236.8 Kbps (DL) / 236.8 Kbps (UL)
  • GPRS: 85.6 Kbps (DL) 1 85.6 Kbps (UL)
  • Software Features
  • Operating System: Windows/Linux/Android
  • Protocol: TCP, IP, IPV4, IPV6, Multi-PDP, FTP, FTPS, HTTP, HTTPS, DNS
  • SMS: supports MT, MO, CB, Text, PDU
  • Firmware Upgrade: USB/FOTA
  • Hardware Specifications
  • SIM Card: 1.8V/3.0V
  • Antenna Interface: IPEX4 Connector(LTE main antenna+LTE diversity antenna + GNSS antenna)
  • Power Supply: 3V-4.2V
  • Form Factor: M.2 B KEY
  • Dimensions: 42.0*31.4*3.8mm/1.65*1.24*0.15”
  • Operating Temperature: -40°C to +85°C
  • SIM7600G-H-M2 4G Communication Module x1
  • Certifications
    Andrew.Wickens Jan 24, 2026
    Powerful and versatile 4G LTE module. The SIM7600G-H-M.2 is a very capable modem with solid performance and stable connections. Works well for data, GPS, and remote connectivity projects. Once set up correctly, it’s reliable under continuous use and integrates nicely with x86 systems and SBCs. Great option for industrial or mobile applications.
    Sevag.Kestenian Jun 18, 2025
    Very Good Product. Very Supportive Customer Service and Fast Delivery.
    Julian.van Hemert Feb 17, 2025
    Setup was easy. There's not really a manual, so I don't really know how it works yet though. I will look into that.
