Fermion: SD3031 Precision RTC Module for Arduino (Breakout)
$4.90
SKU: DFR0998
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.50 10+ items
This RTC module uses the SD3031 chip with a crystal oscillator for high precision timing, ±3.8ppm accuracy at 25°C, powered by CR1220 batteries.
This real-time clock (RTC) module uses the SD3031 chip, which has an integrated crystal oscillator and temperature compensator. This provides high-precision timing and stability. At a temperature of 25 °C, the accuracy is maintained at ±3.8ppm (±0.32832 seconds/day).
The SD3031 can be powered by button-cell batteries. This allows for accurate timing even when the main power source is interrupted. The RTC keeps track of seconds, minutes, hours, days of the week, dates of the month, and months and years. It also automatically adjusts the date at the end of each month and includes leap year corrections. The SD3031 has a built-in 70-byte SRAM for low-power data storage.
Please note that due to recent air cargo regulations, special items such as batteries, magnets, and liquids are strictly audited for air transport. As a result, the RTC module does not come with batteries. You will need to purchase them locally. The button cell model that is compatible with this module is the CR1220.
Fermion: SD3031 Precision RTC module for Arduino Wiring diagram
Wiring diagram of Fermion: SD3031 Precision RTC Module and Arduino Uno
Selection Guide
RTC Module Selection Guide
Figure
SKU
DFR0641
DFR0819
DFR0821
DFR0998
Storage
None
None
236Byte
70Byte
Integrated Resonator
MEMS
XTAL
XTAL
XTAL
Timing Current
2000nA
840nA
1500nA
1800nA
Timing Precision
±5ppm (±0.432s/d)
±3.5ppm (±0.3024s/d)
±3.8ppm (0.32832s/d) @ 25℃
Operating Voltage
3.3V-5.5V
3.3V-5.5V
3.3V-5.5V
3.3V
Operating Temperature
-45℃ to 85℃
-40℃ to 85℃
-40℃ to 85℃
-10℃ to 70℃
A real-time clock (RTC) module with integrated MEMS resonator, reducing the risk of mechanical failure, suitable for scenarios with strong and frequent vibration.
A real-time clock (RTC) module with integrated crystal oscillator, featuring higher precision and lower power consumption, suitable for scenarios requiring high precision and low power.
A real-time clock (RTC) module with integrated crystal oscillator, featuring built-in 236Byte SRAM storage, capable of storing data with ultra-low power consumption, suitable for low-power loT applications requiring real-time clock.
A cost-effective RTC module with integrated crystal oscillator, featuring built-in 70Byte SRAM storage, capable of storing data with ultra-low power consumption, suitable for low-power loT applications requiring real-time clock.
Add to Cart
  • Low power consumption, operating current of only 1.8µA when powered by button cell battery
  • High precision, ±3.8ppm@25℃
  • Integrated temperature compensator, small temperature drift
  • Readable button cell voltage
  • Built-in 70Byte SRAM
  • Event Reminder
  • Countdown Devices
  • MCU External Wake-up Source
  • Clock & Alarm Output
  • IoT Data Collection & Storage
  • Supply Voltage: 3.3V
  • I2C Address: 0x32
  • SRAM: 70 Byte (0x2C-0x71)
  • Timing Year Range: 2000 - 2099
  • Operating Temperature: -10℃ to +70℃
  • Timing Accuracy: ±3.8ppm @ 25℃
  • Dimension: 22.5x21mm/0.89x0.83"
  • Fermion: SD3031 RTC module (Breakout) × 1
  • 2.54-7P Black Single-row Pin Connector × 1
