ROCK Pi 4 Model SE - Rockchip RK3399-T ARM Single Board Computer (4GB DDR4)
$85.00
SKU: DFR1051
A high-performance ARM SBC, featuring a Rockchip RK3399-T processor, 4GB RAM, extensive storage, RTC, WiFi, Bluetooth, HDMI, and audio jack for multimedia.
Purchase this product and earn 850 reward points, which are tied to VIP membership program. Learn More >
ROCK 4 SE is a reliable and high-performing ARM SBC (Single Board Computer) that offers class-leading performance and superior hardware as standard. This special edition board is based on a powerful Rockchip RK3399-T hexa-core processor and equipped with Arm® big.LITTLE™ technology dual Cortex-A72®CPU, quad Cortex-A53 CPU, Arm Mali™-T860MP4 GPU, and 4GB of 64-bit LPDDR4 RAM. With onboard RTC, WiFi, Bluetooth, antenna, audio jack, 4K HDMI port, and many more features, ROCK 4 SE is the perfect Raspberry Pi alternative, that provides an incredible performance as solid as a ROCK!
Note: We recommend using a PD or QC power supply with a maximum output of 9V or 12V.
Features of ROCK Pi 4 SE Single Board Computer
Figure: Features of ROCK 4 SE
Powerful Rockchip processor
A low-power high-performing Rockchip RK3399-T processor is embedded into the heart of the ROCK 4 SE board. Equipped with an Arm® big.LITTLE™ technology dual Cortex®[email protected], quad [email protected] CPU, Arm Mali™ – T860MP4 GPU and 4GB 64bit LPDDR4 RAM, be sure that your board will provide a high-performance solid as a ROCK!
Extensive storage capacity
ROCK 4 SE offers you an immense advantage over other competitors’ boards, benefiting from extensive storage capability. It features a Micro SD card, an eMMC and an M.2 (M key), ensuring the board with a tremendous amount of additional storage capacity.
RTC (real-time clock)
The onboard real-time clock allows you to accurately register the time even when the ROCK 4 SE is powered off. The board features an onboard connector for an RTC battery.
Multiple connectivity capabilities
The board offers you multiple connectivity capabilities, including Bluetooth 5.0, WiFi, Gigabit Ethernet, USB and HDMI ports, and a built-in antenna, allowing users to widely incorporate ROCK 4 SE into applications.
Highly compatible with SBC accessories
ROCK 4 SE features an onboard 40P GPIO extension header, offering extensive compatibility with a wide range of SBC accessories.
Pinout of ROCK Pi 4 SE Single Board Computer
Figure: Pinout of ROCK 4 SE
System of ROCK Pi 4 SE Single Board Computer
Figure: ROCK 4 SE OS
Advanced multimedia functions
The ROCK 4 SE is fitted with an Arm Mali™ – T860MP4 quad-core graphics processing unit (GPU), ideal for advanced multimedia applications, including games. The board incorporates a camera and display interfaces, an HDMI port supporting displays up to 4Kp60 resolution, a high-quality audio output via a 3.5mm onboard audio jack that supports microphone input as default, and much more.
  • Better performance – 4GB 64bit RAM, more processing cores, and a broader memory interface
  • Extensive storage capacity
  • Similar form factor and Interface layout
  • 40 pin GPIO extension header
  • ROCK Pi 4 SE Single Board Computer Board Interface
    Figure: ROCK 4 SE Board Interface
    ROCK Pi 4 SE Single Board Computer Dimensional Drawing
    Figure: Dimensional Drawing
    Top of Radxa ROCK 4SE vs. Raspberry Pi 3B vs. Raspberry Pi 4B
    Bottom of Radxa ROCK 4SE vs. Raspberry Pi 3B vs. Raspberry Pi 4B
    Figure: Board Overvire of Radxa ROCK 4SE vs. Raspberry Pi 3B vs. Raspberry Pi 4B
    Selection Guide
    Raspberry Pi 4B vs. ROCK 4 SE
    Figure
    SKU
    DFR0619
    DFR1051
    CPU
    1.5GHz, quad-core Broadcom BCM2711(Cortex A72)
    Hexa-core, including 1.5GHz dual Cortex A72 &1.0GHz quad Cortex A53
    Memory
    1-4GB DDR4
    4GB DDR4
    GPU
    500 MHz Videocore VI
    Arm Mali™-TB60MP4
    Video Output
    Dual micro HDMI ports
    One standard HDMI port
    Maximum Resolution
    4K & 60Hz 1080P or dual 4K & 30Hz
    4K@60fps
    USB Port
    2 x USB3.0 + 2 x USB2.0
    Wired Network
    Gigabit Ethernet
    Gigabit Ethernet
    Wireless Network
    802.11ac (2.4/5GHz),Bluetooth 5.0
    802.11 b/g/n/ac,Bluetooth 5.0
    Power Supply Port
    Type-C (5V 3A)
    USB Type-C PD 2.0,9V/2A,12V/2A
    EMMC
    M.2 port
    MIPI
    2-lane MIPI DSI display port 2-lane MIPI CSI camera port
    Add to Cart
  • IoT connectivity
  • Computer Vision applications
  • Robotics
  • SOC: Rockchip RK3399-T
  • Processor: Arm®big.LITTLE™technology (Dual Cortex®[email protected], Quad [email protected]
  • GPU: Arm Mali™–T860MP4 GPU
  • Memory: Dual channel (64bit) 4GB LPDDR4 RAM
  • Power Req: USB Type-C™ PD/QC 9-12V
  • HDMI: 1 × 4k@60fps HDMI
  • USB: 2 × USB 2.0, 1 × USB 3.0, 1 × USB 3.0 OTG (Switchable)
  • Audio Ports: 3.5mm jack, analog stereo output, microphone input
  • Connectivity: WiFi 5/BT 5.0, BLE, Gigabit Ethernet
  • MIPI: 1 × 2 lane DSI, 1 × 2 lane CSI
  • Storage: Micro SD/M.2(M key)/eMMC
  • EMMC: B2B connector
  • UART: 2 × UART
  • RTC: Yes (support for external battery)
  • Software
           ARMv8 Instruction Set
           Debian/Ubuntu Linux support
           Android7.1/Android 9.0/Android 10/Android 11 support
           GPU-enabled AI stack such as Caffe
           Hardware access/control library for Linux/Android
  • Operation Temperature: 0 to 50 ℃
  • Storage Temperature: -20 to 80 ℃
  • ROCK 4SE 4GB Single Board Computer × 1
  • ROCK Pi 4 Model SE - Rockchip RK3399-T ARM Single Board Computer (4GB DDR4)
