Flexible LED Filament (12V 600mm, 2200K)
$5.90
SKU: FIT0926
  • $5.80 3+ items
  • $5.70 5+ items
  • $5.50 10+ items
A 600mm flexible LED filament with 320 LEDs, 360° lighting, adjustable brightness, and requires 12V power. Ideal for DIY and various applications.
This high-brightness flexible filament has a diameter of only 2mm and a length of 600mm. It is composed of 320 LEDs and can be used for DIY lighting decoration and 360° all-angle lighting fixtures. It requires a power supply of 12V and comes with adjustable brightness. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament can be bent and folded at will, with 360-degree light without dead angles.
Dimension of Flexible LED Filament
Figure: Dimension
24V 1200mm LED Flexible Filament (2700K) 24V 1200mm LED Flexible Filament (2200K)
24V 1200mm Green LED Flexible Filament 24V 1200mm Red LED Flexible Filament
24V 1200mm Blue LED Flexible Filament 12V 600mm LED Flexible Filament (2200K)
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
  • 600 mm in length, high brightness, suitable for DIY
  • Compact size, positive and negative poles identified
  • Flexible filament, can be bent and folded as desired.
  • Long lifespan of 5000-10000 hours
  • E-Textiles (smart fabrics): Incorporate electronic functionality.
  • LED filament light bulbs: Resemble traditional incandescent light bulbs with visible filaments for aesthetic and light distribution purposes but with the high efficiency of light-emitting diodes (LEDs).
  • Length: 600mm
  • Emitting Color: 2200K (Warm White)
  • Color Rendering Index: 80
  • Luminous Flux: 400 lm
  • Supply Voltage: 12V
  • Working Current: 500mA
  • Power: 6W
  • Operating Temperature: -30 to +55°C
  • Storage Temperature: -10 to +40°C
  • Storage Humidity: 60%RH
  • Lifespan: 5000-10000 hours
  • 12V 600mm LED Flexible Filament (2200K) x1
  • Only 1 Left
