This high-brightness flexible filament has a diameter of only 2mm and a length of 600mm. It is composed of 320 LEDs and can be used for DIY lighting decoration and 360° all-angle lighting fixtures. It requires a power supply of 12V and comes with adjustable brightness. The small round hole end is the positive electrode, and the non-porous end is the negative electrode. The filament can be bent and folded at will, with 360-degree light without dead angles.
Figure: Dimension
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
