This flexible filament is 1200mm long, with a diameter of only 2mm and 640 LEDs. It can be used for DIY lighting decoration and 360° all-angle lighting fixtures. It comes with adjustable brightness and requires a 21-24V power supply. The positive electrode is at the small round hole end and the negative electrode is at the non-porous end. It can be bent and folded as desired, providing 360-degree light without dead angles.
Note: To avoid excessive heat that can damage the filament, a power supply of 21-22V is recommended for long-term use.
Figure: Dimension
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
Aug 04, 2025
Very Good Service Will Use Again
