With a diameter of 2mm and a length of 1200mm, this flexible filament boasts 640 LEDs, making it perfect for DIY lighting decoration and 360° all-angle lighting fixtures. It comes with adjustable brightness and requires a power supply of 21-24V. The positive electrode is located at the small round hole end, while the negative electrode is at the non-porous end. Its bendable and foldable design provides 360-degree light without dead angles.
Note: To prevent damage to the filament, it is recommended to use a power supply of 21-22V for prolonged use due to heat generation.
Figure: Dimension
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
Aug 04, 2025
Very Good Service Will Use Again
