With a diameter of 2mm and a length of 1200mm, this flexible filament boasts 640 LEDs, making it perfect for DIY lighting decoration and 360° all-angle lighting fixtures. It comes with adjustable brightness and requires a power supply of 21-24V. The positive electrode is located at the small round hole end, while the negative electrode is at the non-porous end. Its bendable and foldable design provides 360-degree light without dead angles.
Note: To prevent damage to the filament, it is recommended to use a power supply of 21-22V for prolonged use due to heat generation.
Figure: Dimension
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
1200mm in length, high brightness, suitable for DIY
21-24V power supply, adjustable brightness
Compact size, positive and negative poles identified
Flexible filament, can be bent and folded as desired
Long lifespan of 5000-10000 hours
E-Textiles (smart fabrics): Incorporate electronic functionality.
LED filament light bulbs: Resemble traditional incandescent light bulbs with visible filaments for aesthetic and light distribution purposes but with the high efficiency of light-emitting diodes (LEDs) .
Length: 1200mm
Emitting Color: 2700K(Warm white)
Color Rendering Index: 80
Luminous Flux: 500lm
Supply Voltage: 21-24V
Working Current: 300mA @ 22V
Power: 6.6W @ 22V
Operating Temperature: -30 to +55°C
Storage Temperature: -10 to +40°C
Storage Humidity: 60%RH
Lifespan: 5000-10000 hours
24V 1200mm LED Flexible Filament (2700K) x1
Jonathan.Downing Aug 04, 2025
