This high-brightness flexible filament is 1200mm long and 2mm in diameter, consisting of 640 LEDs. It can be used for DIY lighting decoration and 360° all-angle lighting fixtures, with adjustable brightness and requiring a 21-24V power supply. The positive electrode is located at the small round hole end and the negative electrode at the non-porous end. It can be bent and folded according to your requirements, offering 360-degree light coverage.
Note: To prevent filament damage from excessive heat, it is recommended to use a 21-22V power supply for prolonged use.
Figure: Dimension
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
