Raspberry Pi Debug Probe Kit for Pico
$12.00
SKU: FIT0933
The Debug Probe is a USB to serial debug and UART bridge, supporting plug-and-play debugging for microcontrollers, compatible with multiple platforms.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
The Raspberry Pi Debug Probe is an all-in-one USB to serial debug and UART bridge.
Powered by an RP2040, it provides the necessary hardware and cabling to support “plug and play” debugging of Raspberry Pi Pico and other microcontroller and microprocessor-based platforms.
Board Overview of the Raspberry Pi Debug Probe Kit
Raspberry Pi Debug Probe Kit Pinout
Board Overview of the Debug Probe
Featuring a USB to two-wire serial debug bridge and a USB to UART bridge, the Debug Probe makes it easy to use devices such as Raspberry Pi Pico with a range of host platforms including PC, Mac, and typical Linux computers.
Shipping List of Raspberry Pi Debug Probe Kit
Raspberry Pi Pico Debug Probe Wires
Wiring Diagram of the Debug Probe to a Raspberry Pi Pico
While designed for use with Raspberry Pi products, the debug probe also provides standard UART and CMSIS-DAP interfaces over USB, so it can also be used to debug any Arm-based microcontroller that provides an SWD port with 3V3 I/O, or even just as a USB-to-UART cable. It works well with OpenOCD and other tools that support CMSIS-DAP.
The Debug Probe is based on Raspberry Pi Pico hardware and runs the open-source Raspberry Pi Picoprobe software. The firmware is updated in the same way as Raspberry Pi Pico firmware, so it is easy to keep the unit up to date with the latest firmware, or to use custom firmware.
  • All-in-One Kit: Complete hardware and cables for easy debugging.
  • Plug-and-Play: Solderless, hassle-free setup.
  • Dual Interfaces: Processor serial debug and UART interfaces.
  • Versatile Compatibility: Works with Raspberry Pi products and other Arm-based microcontrollers.
  • Host Platform Support: Compatible with Windows, Mac, and Linux computers.
  • Open Source Software: Runs Raspberry Pi Pico probe software, upgradable and customizable.
  • Wide Range of Applications: Suitable for industrial machinery, robotics, and more.
  • Development Tool Compatibility: Works with OpenOCD and CMSIS-DAP supported tools.
  • Firmware Updates: Easily update firmware for compatibility and customization.
  • Portable and Durable: Comes in a protective case for portability and durability.
  • Bug hunting
  • Serial communication
  • Microcontroller chip: Raspberry Pi's RP2040
  • Onboard port : Micro-USB
           3-pin SWD port
           3-pin UART port
           Standard CMSIS-DAP port
  • Form Factor: 32*22mm/1.26*0.87”
  • Voltage: 3.3V
  • Operating Temperature: -20°C to +70°C.
  • Debugging tools: OpenOCD and other debugging tools supporting CMSIS-DAP
  • Raspberry Pi Debug Probe Kit × 1
  • Debug Probe Transparent Case × 1
  • JST-SH Debugging Cable × 3
  • Micro-USB Cable × 1
  • Raspberry Pi Debug Probe Kit for Pico
