The Arduino Nano ESP32 is a development board in the Nano form factor, featuring the u-blox® NORA-W106 module which is based on the Espressif ESP32-S3. The microcontroller has a clock speed of up to 240 MHz, 512 kB of SRAM, and 16 MB of external flash memory. It provides Wi-Fi and Bluetooth connectivity. The board has 14 digital I/O pins, 8 analog inputs, and 5 PWM pins. It uses a USB-C connector for power and programming and operates with an I/O voltage of 3.3V. It is fully supported by the Arduino ecosystem, including the Arduino IDE and MicroPython.
The Arduino Nano ESP32 combines the accessibility and support of the Arduino brand with the robust capabilities of the ESP32-S3.
Even if you are a newbie or you have experience with Arduino and want to learn micro python, the Arduino Nano ESP32 is the best way to start.
Figure: Board Overview of Arduino Nano ESP32 micro-controller
Jul 17, 2025
i got it well. the shipping was so fast and delivery status was very good.
