Miniware TS1C Smart Cordless Soldering Station (Supports Bluetooth & Super Capacitor)
$145.00
SKU: FIT0960
Cordless smart soldering station with super-capacitor, OLED display, Bluetooth control, fast charging, and USB-C PD input. Compact and safe design.
Purchase this product and earn 1450 reward points, which are tied to VIP membership program. Learn More >
The Miniware TS1C soldering station is a cordless smart soldering station which uses a super-capacitor inside the soldering iron. The super capacitor is good for many soldering joints, and we can keep an eye on the power and temperature status using the OLED display. The soldering iron and station are linked together using Bluetooth.
Miniware TS1C soldering station features
Super Capacitor Energy Storage Technology
Extraordinary hard-core energy storage technology by a 750F super capacitor provide 36W max. heating power and more than 180 soldered dots (based on 0805 SMD) truly achieve wireless welding freedom
Long lifetime and fast charging speed in only 7 minutes are better than traditional battery power system
Remote Control by Bluetooth Connection
Bluetooth communication between the station and the soldering iron achieves remote control and setting with soldering iron preheating, temperature adjustment, and an information display convenient to use
Multifunction Station
Set soldering control, soldering charging, soldering stand and 3 expansion slots at the bottom of the station, all in one
USB Type C PD Charger Input
USB type C power jack with PD2.0 power system max. 45W input which can be powered easily
It comes with soft silicone rubber USB cable and 45W PD Charger
Safe to Use
Support auto-sleep, auto-cool down, charging protection, under-voltage protection and over-temperature protection.
Compact Desktop Soldering Station
A compact pen-shaped size with only 23mm diameter and 133mm long handle is convenient to grip and store, saving space
Wireless Communication
BLE 4.2 Bluetooth communication technology enables remote control and settings.
Display
A 128*64-pixel OLED screen displays the real-time status of the soldering handle.
Interface
Compatible with MINIWARE 3.5mm audio interface soldering tips (TS80/80P series soldering tips).
TS1C Control Base
  • Model: TS1C-S
  • Screen: 128*64 pixel monochrome OLED
  • Maximum Input Voltage: PD2 20V
  • Maximum Input Power: 45W
  • Safety Protection: Overcurrent protection
  • Dimensions: Base 44.5*122*73mm, Sponge Slot 42*43mm
  • Weight: 186g
  • TS1C Soldering Iron Handle
  • Model: TS1C-P
  • Interface Type: USB Type-C
  • Capacitance: 750F
  • Charging Time: 7 minutes
  • Maximum Heating Power: 36W
  • Temperature Range: 100°C~400°C (212°F~752°F)
  • Temperature Stability: ±3%
  • Soldering Tip: MINWARE 3.5mm audio jack soldering tip
  • Safety Protection: Low voltage protection for the capacitor, capacitor charging protection, over-temperature protection
  • Dimensions: 23*133mm
  • Weight: 62g
  • TS1C Soldering Iron Handle (Black) x1
  • TS1C Control Base x1
  • Soldering Tip (TS-B02) x1
  • Sponge Tray x1
  • Absorbent Sponge x1
  • USB-C Silicone Power Cable x1
  • User Manual x1
  • Only 4 Left
