Miniware TS1C Smart Cordless Soldering Station (Supports Bluetooth & Super Capacitor)
$145.00
SKU: FIT0960
Cordless smart soldering station with super-capacitor, OLED display, Bluetooth control, fast charging, and USB-C PD input. Compact and safe design.
Purchase this product and earn 1450 reward points, which are tied to VIP membership program. Learn More >
Miniware TS1C Cordless Smart Soldering Station introduces a new approach to portable electronics assembly by integrating super‑capacitor energy storage directly inside the soldering handle. This compact desktop soldering solution eliminates conventional battery packs while still delivering rapid heating and consistent temperature performance. A 128×64 OLED screen provides clear real‑time information such as temperature and power status, while Bluetooth connectivity links the handheld soldering unit with the control base for convenient wireless configuration. Combining fast charging, stable heating output, and a compact pen‑style form factor, this portable soldering platform offers an efficient workspace tool for electronics prototyping, repair tasks, and precision SMD soldering.
Miniware TS1C soldering station features
Figure: Miniware TS1C soldering station features
Super Capacitor Wireless Power System
A 750F super‑capacitor energy storage architecture replaces traditional lithium batteries, enabling stable high‑current delivery and long operational lifespan. This cordless soldering platform provides up to 36W heating power while supporting more than 180 solder joints based on 0805 SMD components per charge cycle. Fast recharge capability restores full energy in approximately seven minutes, minimizing downtime during assembly work. Super‑capacitor technology also offers superior durability compared with conventional battery systems, supporting repeated charge cycles while maintaining reliable heating performance during mobile electronics repair and field engineering tasks.
Bluetooth Remote Control and Smart Interaction
Wireless BLE 4.2 communication connects the soldering handle with the control base, enabling remote configuration and monitoring. Temperature settings, preheating control, and operational information can be adjusted directly through the station interface while the soldering pen remains cordless. A 128×64 pixel OLED display integrated into the handle presents real‑time operating status including temperature and power levels. This intelligent communication design simplifies workflow management and improves usability during detailed soldering work on compact electronics assemblies.
Integrated Multifunction Control Base
The docking base combines several essential workstation functions into a compact structure. Charging circuitry, soldering stand support, and system control electronics are integrated into a single platform, reducing clutter on the electronics workbench. Three expansion slots located at the bottom of the base allow additional accessory modules or storage solutions to be added. This integrated design creates a practical desktop soldering environment while maintaining efficient charging and convenient placement of the soldering handle during pauses between tasks.
USB‑C PD Fast Charging with Comprehensive Protection
Power delivery is supported through a USB Type‑C interface with PD2.0 protocol, allowing input power up to 45W. This flexible charging method enables compatibility with common USB‑C power adapters and modern workstation chargers. Built‑in safety mechanisms include automatic sleep mode, automatic cooling, charging protection, under‑voltage protection, and over‑temperature protection. The included silicone USB‑C cable and 45W PD charger ensure reliable operation while maintaining a safe and efficient charging process for the portable soldering system.
The compact pen‑style soldering handle measures only 23mm in diameter and 133mm in length, offering a comfortable grip suitable for precision work on dense circuit boards. Compatibility with MINIWARE 3.5mm audio interface soldering tips from the TS80 and TS80P series provides flexible tip selection for different soldering tasks.
This portable smart soldering station supports electronics prototyping, SMD assembly, repair work, and compact lab workstations. Wireless operation combined with fast charging and precise temperature control makes this super‑capacitor powered soldering solution suitable for engineers, makers, and technical laboratories requiring flexible soldering capability.
  • 750F super‑capacitor energy storage system for cordless operation
  • Maximum heating power up to 36W
  • Fast charging in approximately 7 minutes
  • BLE 4.2 Bluetooth communication between handle and base
  • 128×64 pixel OLED display for real‑time status
  • Temperature adjustment range from 100°C to 400°C
  • USB Type‑C PD2.0 input supporting up to 45W
  • Integrated multifunction charging and control base
  • Auto sleep, auto cooling, and multiple protection mechanisms
  • Compatible with MINIWARE TS80/TS80P 3.5mm audio jack soldering tips
  • Electronics prototyping and circuit debugging
  • SMD component soldering and PCB assembly
  • Portable electronics repair
  • Engineering laboratory workstations
  • Maker and hardware development projects
    TS1C Control Base
  • Model: TS1C-S
  • Screen: 128*64 pixel monochrome OLED
  • Maximum Input Voltage: PD2 20V
  • Maximum Input Power: 45W
  • Safety Protection: Overcurrent protection
  • Dimensions: Base 44.5*122*73mm, Sponge Slot 42*43mm
  • Weight: 186g
  • TS1C Soldering Iron Handle
  • Model: TS1C-P
  • Interface Type: USB Type-C
  • Capacitance: 750F
  • Charging Time: 7 minutes
  • Maximum Heating Power: 36W
  • Temperature Range: 100°C~400°C (212°F~752°F)
  • Temperature Stability: ±3%
  • Soldering Tip: MINWARE 3.5mm audio jack soldering tip
  • Safety Protection: Low voltage protection for the capacitor, capacitor charging protection, over-temperature protection
  • Dimensions: 23*133mm
  • Weight: 62g
  • TS1C Soldering Iron Handle (Black) x1
  • TS1C Control Base x1
  • Soldering Tip (TS-B02) x1
  • Sponge Tray x1
  • Absorbent Sponge x1
  • USB-C Silicone Power Cable x1
  • User Manual x1
  • Only 3 Left
