Metal Cooling Case with Heat Sink (Compatible with Raspberry Pi CM4 IoT Router Carrier Board)
$19.90
SKU: FIT0788-V2
  • $19.30 3+ items
  • $18.90 5+ items
  • $18.30 10+ items
This kit includes an aluminum case and heat sink for the Raspberry Pi CM4 IoT Router Carrier Board Mini, ensuring optimal cooling and protection against short circuits.
This is an Aluminum case and heat sink kit built specifically for the Raspberry Pi CM4 IoT Router Carrier Board Mini. The kit allows the Raspberry Pi CM4 IoT Router Carrier Board Mini to be safely housed within a power distribution box, eliminating concerns about short circuits on the exposed PCB.
The cooling solution kit features an integrated all-metal casing and heat sink, engineered to efficiently dissipate heat from the BCM2711. This ensures optimal performance by preventing overheating, even when operating at full capacity.
Installation Steps of CM4 IoT Router Mini and Case
  • Size: 59mm×69mm×29mm
  • Shell Material: Aluminum
  • Heatsink Material: Aluminum
  • Compatibility: Raspberry Pi Compute Module 4 IoT Router Carrier Board Mini
  • Aluminum shell x1
  • Heatsink x1
  • Parts package x1
                Thermal conductive sheet – Thick (for Raspberry Pi CM4) x1
                Thermal conductive sheet – Thin (for other CM4 compatible modules) x1
                Screw x1
                Antenna Hole Plug x1
  • (Not Include Compute Module 4 IoT Router Carrier Board Mini)
