Full-Metal Case for Raspberry Pi 5 Single Board Computer
$14.90
SKU: FIT0963
  • $14.50 3+ items
  • $14.20 5+ items
  • $13.80 10+ items
Metal kit for Raspberry Pi 5 offers efficient heat dissipation with a copper sheet, adjustable fan, and metal casing. Easy assembly and dual cooling features.
This is a metal heat dissipation kit designed specifically for Raspberry Pi 5. The case is made entirely of metal, offering strong thermal conductivity and high strength. The kit includes a metal case, equipped with a heat-dissipating copper sheet, an adjustable-speed fan, and heat-dissipating holes on the top of the metal case.
With this case, not only can it effectively protect the motherboard, but the adjustable-speed fan can also automatically adjust its speed based on the temperature of the Raspberry Pi 5, ensuring efficient heat dissipation and maintaining stability and reliability during high-performance operations.
Dimension of Metal Heat Dissipation Kit for Raspberry Pi 5 Single Board Computer
Installation Steps of Metal Heat Dissipation Kit and Raspberry Pi 5 Single Board Computer
  • Excellent Heat Dissipation Performance
  • Easy Assembly
  • Dual heat dissipation with heat sink and cooling fan
  • Compatibility: Raspberry Pi 5 4GB and 8GB
  • Dimensions: 92 x 66 x 40mm
  • Weight: 210g
  • Adjustable speed fan ×1
  • M2.5 Screw drive ×1
  • M2.5 nuts ×4
  • M2.5 ball head screws ×4
  • Hand tightened copper nut ×4
  • Copper pillar ×4
  • M2.5 screws for case ×8
  • Copper Heat sinks ×4
  • Transparent anti - slippery rubber feets ×4
  • Full-Metal Case for Raspberry Pi 5 Single Board Computer
