8.8" 480×1920 IPS Bar Touch Display (Compatible with Raspberry Pi 4B / 3B+ / 3B)
$72.00
SKU: FIT0941
8.8-inch touch display features 480×1920 resolution, 4:1 aspect ratio, and IPS technology, perfect for Raspberry Pi applications such as advertising and smart home displays.
Purchase this product and earn 720 reward points, which are tied to VIP membership program. Learn More >
The 8.8" 480×1920 DSI Bar Touch Display for Raspberry Pi is a high‑resolution capacitive touchscreen engineered for projects requiring a compact yet information‑dense visual interface. Featuring a distinctive 4:1 bar‑type aspect ratio and a 480×1920 vertical resolution, this IPS display module delivers clear graphics within narrow installation spaces. Optical bonding and 600cd/m² brightness enhance visibility and durability, while the DSI interface enables direct connection with compatible Raspberry Pi boards for rapid prototyping. Such characteristics make the elongated touchscreen panel suitable for dashboards, data panels, embedded control interfaces, and creative display installations.
Distinctive 4:1 Bar‑Type Display Format
This 8.8‑inch elongated touchscreen adopts a 1:4 aspect ratio that differs from conventional displays, allowing information to be arranged in long vertical or horizontal layouts. The bar‑type format enables clearer organization of data streams, system indicators, or multimedia content without frequent page switching. Compared with traditional screens, this specialized display panel supports space‑efficient installation inside narrow enclosures, instrument housings, or shelf structures while maintaining a visually clean and structured presentation.
High‑Quality IPS Panel with Optical Bonding
An IPS display panel combined with optical bonding technology ensures vivid image quality and strong durability for embedded systems. The 480×1920 high‑definition resolution provides detailed graphics, while a brightness level of 600cd/m² improves readability in bright indoor environments. Wide 170° viewing angles allow content to remain clear from multiple perspectives, making the bar display suitable for information boards, control dashboards, or commercial advertising installations where consistent visibility is important.
Responsive 5‑Point Capacitive Touch Interaction
The integrated five‑point capacitive touch interface enables intuitive interaction for modern human‑machine interfaces. Multi‑touch capability supports gesture‑based control, interactive menus, and responsive graphical dashboards. Combined with the elongated screen format, this touch‑enabled display module simplifies the design of control panels, interactive kiosks, and embedded monitoring systems while maintaining a streamlined user interface.
Native DSI Connectivity for Rapid Development
A dedicated DSI interface allows seamless integration with compatible Raspberry Pi boards, simplifying hardware connections and enabling efficient display control. This direct connection eliminates the need for complex video adapters and ensures stable high‑speed data transmission. Such compatibility makes the bar touchscreen an effective visualization component for embedded Linux systems, multimedia terminals, and custom hardware prototypes built around Raspberry Pi computing platforms.
Figure: Function Indicator Diagram of 8.8" Touch display
Figure: Wiring Diagram of 8.8" Touch display and Raspberry Pi Single Board Computer
The elongated touchscreen display serves a wide variety of embedded visualization tasks. Typical uses include desktop information displays, measurement instrument panels, shelf advertising screens, and interactive control interfaces. Combined with the multimedia capabilities of Raspberry Pi systems, the bar‑format display panel enables creative installations such as smart home dashboards, IoT data terminals, robotic control displays, and compact multimedia signage.
  • 480×1920 high-definition resolution
  • 1:4 bar-type display aspect ratio
  • 600cd/m² high brightness
  • IPS panel
  • Full bonding process
  • 5-point capacitive touch
  • Raspberry Pi DSI driver
  • Compatible with Raspberry Pi 4B/3B+/3B
  • Music spectrum analyzer
  • Advanced calculator
  • Mini weather station
  • Simulator gaming console
  • IoT terminal data panel
  • Electronic photo album
  • Touchscreen digital control panel
  • Car modification dashboard
  • Measurement instrument panel
  • Robot display panel
    Basic Parameters
  • Operating Voltage: 5V
  • Power Interface: USB-C
  • Static Working Current: Approximately 700mA
  • Display Interface: Raspberry Pi DSI
  • 2P - Spring Plunger: Power Interface, 5V 1.5A
  • Raspberry Pi Mounting Hole Size: 58mm x 49mm
  • Driver Board PCB Size: 93mm×51mm×1.6mm
  • Weight: 278g
  • Screen Parameters
  • LCD Size: 8.8 inch
  • Resolution: 480×1920
  • Pixel Pitch (mm): 0.114(H) x 0.114(V)
  • Pixel arrangement: RGB Vertical stripe
  • NTSC: 50%
  • Viewing Angle: 170°
  • Refresh Rate: 60Hz
  • Contrast Ratio: 800 : 1
  • Response Time: 30ms
  • Brightness: 600cd/m²
  • Bonding Method: Optical bonding
  • Touch Points: 5-point capacitive
  • Viewing Area (mm): 54.72(W)×218.88(H)
  • Dimensions (mm): 64.3(W)×231.3(H)×18(T)
  • 8.8" 480×1920 DSI Bar Touch display for Raspberry Pi x1
  • FPC DSI Cable 50mm x1
  • M2.5*6 Mounting Screws x8
