Argon NEO 5 BRED Case for Raspberry Pi 5 combines durable aluminum construction with an integrated cooling architecture designed for stable single‑board computer operation. The aluminum alloy enclosure features a polished finish and compact structure while providing physical protection and thermal management for the Raspberry Pi 5. A removable top cover shields connectors when interfaces remain unused, while quick access allows convenient interaction with ports whenever expansion hardware is required. Integrated SD card protection, a built‑in power button, and a status LED indicator allow convenient system control and monitoring without removing the enclosure.
Figure: Dimensions of Argon NEO 5 BRED Case
Figure: Interface Diagram of Argon NEO 5 BRED Case
Efficient Hybrid Cooling Design
This aluminum enclosure integrates passive heat dissipation with active airflow assistance. The metal shell works as a heat spreader while the internal cooling fan improves air circulation through dedicated intake openings. Cold air enters the enclosure, heat transfers through the aluminum structure, and warm air exits through the airflow path created by the fan system. This thermal management structure helps prevent overheating during demanding computing tasks, improving long‑term stability for embedded computing workloads built on the Raspberry Pi platform.
Integrated Protection and Hardware Access
This compact SBC protective enclosure safeguards both the board and storage media during operation. A built‑in SD card protection structure helps secure the memory card from accidental contact or removal. The removable top cover protects interface ports during transport or installation while maintaining quick accessibility when peripherals or cables require connection. Such a structure suits embedded deployments, desktop computing setups, and development environments where both protection and accessibility remain important.
Convenient Power Control and Status Indication
An integrated power button and LED indicator allow direct control and monitoring without removing the protective shell. The built‑in button connects to the onboard power control interface, enabling quick startup or shutdown operations while the enclosure remains installed. A visible LED window provides immediate visual feedback on system activity and power state, improving usability for developers, makers, and embedded system deployments that require frequent monitoring.
This aluminum cooling case serves as a practical accessory for single‑board computer installations requiring thermal stability, hardware protection, and easy interface access. Suitable environments include edge computing devices, home automation hubs, media centers, development workstations, and compact embedded systems built around Raspberry Pi 5 hardware.
