Aluminum Argon NEO 5 BRED Case with Built-in Cooling Fan (Compatible with Raspberry Pi 5)
$19.00
SKU: FIT0991
  • $18.50 3+ items
  • $18.00 5+ items
  • $17.50 10+ items
Aluminum heat sink for Raspberry Pi 5 with easy assembly, SD card protection, power button, LED indicator, and efficient passive and active cooling.
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
This Raspberry Pi 5 heat sink is made of aluminum alloy and has a polished surface, making it very delicate. It is easy to assemble and has a compact structure. The top cover can effectively protect the Raspberry Pi 5 when not using various interfaces. When you need to use the various interfaces of the Raspberry Pi 5, you can remove it easily. It also has an SD card protection device, which can effectively protect the SD card. Additionally, it integrates a power button and LED indicator. Even without removing the case, you can control the power button of the Raspberry Pi 5 and check its running status.
It adopts a passive heat dissipation method with an aluminum shell and active heat dissipation with a cooling fan. The intake allows cold air to enter, and the cooling fan helps to circulate airflow and expel hot air, effectively solving the problem of excessive heat during the use of the Raspberry Pi 5. It is suitable for various occasions requiring heat dissipation for the Raspberry Pi 5.
Dimensions of Argon NEO 5 BRED Case
Interface Diagram of Argon NEO 5 BRED Case
  • Simple and beautifully designed
  • Effective heat dissipation
  • Effective protection for Raspberry Pi 5
  • Compatibility: Raspberry Pi 5 4GB/8GB
  • Material: Aluminum
  • Dimensions: 87.6×71.5×30mm
  • Argon NEO 5 BRED Case for Raspberry Pi 5 x1
  • Aluminum Argon NEO 5 BRED Case with Built-in Cooling Fan (Compatible with Raspberry Pi 5)
