This Raspberry Pi 5 heat sink is made of aluminum alloy and has a polished surface, making it very delicate. It is easy to assemble and has a compact structure. The top cover can effectively protect the Raspberry Pi 5 when not using various interfaces. When you need to use the various interfaces of the Raspberry Pi 5, you can remove it easily. It also has an SD card protection device, which can effectively protect the SD card. Additionally, it integrates a power button and LED indicator. Even without removing the case, you can control the power button of the Raspberry Pi 5 and check its running status.
It adopts a passive heat dissipation method with an aluminum shell and active heat dissipation with a cooling fan. The intake allows cold air to enter, and the cooling fan helps to circulate airflow and expel hot air, effectively solving the problem of excessive heat during the use of the Raspberry Pi 5. It is suitable for various occasions requiring heat dissipation for the Raspberry Pi 5.
Dimensions of Argon NEO 5 BRED Case
Interface Diagram of Argon NEO 5 BRED Case
