The FireBeetle 2 ESP32-S3 (N4) is a main control board based on the ESP32-S3-WROOM-1-N4 module. It contains a Xtensa® dual-core 32-bit LX7 microprocessor running up to 240 MHz, with 512KB SRAM and 4MB Flash. The processor includes AI acceleration capabilities. The board supports dual-mode communication via 2.4GHz Wi-Fi (802.11b/g/n) and Bluetooth 5 (LE) with an onboard antenna. It features onboard Li-ion battery power management with charging. Peripherals include 26 digital I/O pins, 20 ADC channels, 3x UART, 2x I2C, 2x SPI, and an onboard GDI. It is compatible with Arduino IDE, ESP-IDF, and MicroPython.
Rich peripheral interfaces
It includes 26 digital pins, 20 ADC channels, 3 UART interfaces, 2 SPI interfaces, 2 I2C interfaces, 2 I2S interfaces, 10 infrared transceivers, and 10 DMA controller channels. Additionally, it provides an onboard GDI display interface to meet various hardware connection requirements.
Board Overview
Dual power supply modes
It supports two power supply modes: USB and external lithium battery, and can automatically switch between the dual power sources. In addition, it also supports two charging methods: USB and external DC, providing stable and reliable power supply.
Support for multiple programming methods
Including Arduino IDE, ESP-IDF, MicroPython, C language, and Python, catering to the programming preferences of different developers.
Compact design, convenient for embedding
With dimensions of only 25.4mm × 60mm, it has onboard WIFI and Bluetooth antennas and adopts a stamp hole design, making it easy to embed or integrate into PCB prototypes.
Wide range of application scenarios
It is suitable for various scenarios such as home automation renovation, IoT device prototyping, IoT remote monitoring, and remote robot control. Additionally, it is also applicable to low-computational AI edge computing, voice command recognition, text recognition, and sensor data recognition applications.
Furthermore, this product is one of the low-power IoT development boards in the FireBeetle series. If it does not meet your requirements, you can refer to the FireBeetle Series Selection Guide to choose a more suitable model.
Note: This product does not come with a camera interface.
Basic Parameters
Hardware Information
WIFI
Bluetooth
Interface Pins
Apr 13, 2026
Great dev board. I use them for a complete automation project, and they seem to hold up well. I highly recommend these boards for the cost and quality.
