FireBeetle 2 ESP32-S3 (N4) Dual-core IoT Microcontroller (No Cam, 4MB Fl., 512KB SR., Supports AI Acceleration)
$9.90
SKU: DFR1145
The main control board features a dual-core processor, WiFi, Bluetooth 5.0, AI acceleration, rich interfaces, dual power modes, and supports various programming methods.
The FireBeetle 2 ESP32-S3 (N4) is a main control board based on the ESP32-S3-WROOM-1-N4 module. It contains a Xtensa® dual-core 32-bit LX7 microprocessor running up to 240 MHz, with 512KB SRAM and 4MB Flash. The processor includes AI acceleration capabilities. The board supports dual-mode communication via 2.4GHz Wi-Fi (802.11b/g/n) and Bluetooth 5 (LE) with an onboard antenna. It features onboard Li-ion battery power management with charging. Peripherals include 26 digital I/O pins, 20 ADC channels, 3x UART, 2x I2C, 2x SPI, and an onboard GDI. It is compatible with Arduino IDE, ESP-IDF, and MicroPython.
Features of ESP32-S3-WROOM-1-N4 module
Rich peripheral interfaces
It includes 26 digital pins, 20 ADC channels, 3 UART interfaces, 2 SPI interfaces, 2 I2C interfaces, 2 I2S interfaces, 10 infrared transceivers, and 10 DMA controller channels. Additionally, it provides an onboard GDI display interface to meet various hardware connection requirements.
Board Overview of FireBeetle 2 ESP32-S3 (N4) IoT Microcontroller
Board Overview
Dual power supply modes
It supports two power supply modes: USB and external lithium battery, and can automatically switch between the dual power sources. In addition, it also supports two charging methods: USB and external DC, providing stable and reliable power supply.
Support for multiple programming methods
Including Arduino IDE, ESP-IDF, MicroPython, C language, and Python, catering to the programming preferences of different developers.
Support Arduino IDE, ESP-IDF, Micro-Python, C language
Compact design, convenient for embedding
With dimensions of only 25.4mm × 60mm, it has onboard WIFI and Bluetooth antennas and adopts a stamp hole design, making it easy to embed or integrate into PCB prototypes.
Wide range of application scenarios
It is suitable for various scenarios such as home automation renovation, IoT device prototyping, IoT remote monitoring, and remote robot control. Additionally, it is also applicable to low-computational AI edge computing, voice command recognition, text recognition, and sensor data recognition applications.
Furthermore, this product is one of the low-power IoT development boards in the FireBeetle series. If it does not meet your requirements, you can refer to the FireBeetle Series Selection Guide to choose a more suitable model.
Note: This product does not come with a camera interface.
  • Equipped with ESP32-S3-WROOM-1-N4 dual-core module, supporting AI acceleration.
  • Clock frequency up to 240MHz, with built-in 512KB SRAM and 4M Flash.
  • Supports dual-mode communication of Wi-Fi and Bluetooth 5 (LE).
  • Integrated power management, supporting lithium battery charging.
  • Onboard independent GDI display interface, enabling quick connection to display screens.
  • Supports various programming methods such as Arduino IDE, ESP-IDF, and MicroPython.
  • Compact design with small size, suitable for IoT and AIoT projects with limited space and embedded systems.
    Basic Parameters
  • Input Voltage
    USB-C interface: 5V DC
    PH2.0 interface: 3.7V Li-ion
    VCC pin: 5V DC
  • Interface: FireBeetle V2 series compatible
  • Module Size: 25.4mm × 60mm
  • Weight: 23.4g
  • Hardware Information
  • Processor: Xtensa® dual-core 32-bit LX7 microprocessor
  • Clock Frequency: 240 MHz
  • SRAM: 512KB
  • ROM: 384KB
  • Flash: 4MB
  • RTC SRAM: 16KB
  • USB: USB 2.0 OTG full-speed interface
  • WIFI
  • WIFI Protocol: IEEE 802.11b/g/n
  • WIFI Bandwidth: 2.4 GHz band supports 20 MHz and 40 MHz bandwidth
  • WIFI Modes: Station mode, SoftAP mode, SoftAP+Station mode, and mixed mode
  • WIFI Frequency: 2.4GHz
  • Frame Aggregation: TX/RX A-MPDU, TX/RX A-MSDU
  • Bluetooth
  • Bluetooth Protocol: Bluetooth 5, Bluetooth mesh
  • Bluetooth Frequency: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
  • Interface Pins
  • Digital I/O x26
  • SPI x2
  • UART x3
  • I2C x2
  • I2S x2
  • LED PWM controller with 8 channels
  • Infrared transceiver: 5 transmission channels, 5 reception channels
  • 2 × 12-bit SAR ADC, 20 channels
  • DMA controller, 5 reception channels, and 5 transmission channels
  • FireBeetle 2 ESP32-S3 (N4) IoT Microcontroller x1
  • 18-pin 2.54mm pitch male header x1
  • 18-pin 2.54mm pitch female header x1
  • 14-pin 2.54mm pitch male header x1
  • 14-pin 2.54mm pitch female header x1
Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Sep 25, 2023
Voice Controlled DHT11 with DFRobot
Projects Voice Controlled DHT11 with DFRobot
pradeeplogu0
Jun 06, 2024
Matthew.Kinney Apr 13, 2026
Great dev board. I use them for a complete automation project, and they seem to hold up well. I highly recommend these boards for the cost and quality.
Out Of Stock
